10 bolt lengths
Old Jul 27, 2017 | 08:17 AM
71DP's Avatar
10 bolt lengths
I am sure this has been discussed many times but I cant seem to find it... What are the outside drum to drum lengths for the 10 bolts? Looking for a 68-72 and cant recall if the 73-77 are longer?
Old Jul 27, 2017 | 03:39 PM
Kennybill's Avatar
The control arm mounting brackets are different on the 73/77 housings.
Old Jul 27, 2017 | 08:33 PM
monzaz's Avatar
lengths
67-72 55.25 housing flange to housing flange or 61" drum to drum
73-77 56.25 housing flange to housing flange or 62" drum to drum
64-66 54.25 housing flange to housing flange or 60" drum to drum
Jim
J D Race
As stated correctly 73-77 are not interchangeable with 64-72 rears...just way different rears and chassis set-up
Old Jul 31, 2017 | 08:33 AM
71DP's Avatar
Ahhh, thank you! Anybody have a pic what the difference in mounting locations are?
Old Jul 31, 2017 | 01:42 PM
cdrod's Avatar
Rodney
Vista rear
Are the Vista Cruiser rears wider? I know they use a larger brake shoe than a 2-door model, not sure how that affects the width.
Old Aug 1, 2017 | 02:25 PM
monzaz's Avatar
cruiser differences
No they are the same width - drums are wider inward...backing plates have more backspacing to use 2.5" shoes not the 2" shoes.
The shock mounts are extended, and the frame bump stops are sideways compared to sedan and coupe or convertible rears as the frame rails are probably slightly wider where they would bump the rear end housings if it hit a big enough chuck hole. ...But that is about all the difference.
Obviously axle bearings are different too because wagons carry more weight.
2blu442
Tech Editor's Desk
99
Jul 13, 2024 02:04 PM
bummerino
Oct 25, 2011 08:28 AM
oldzy
Jun 29, 2011 10:07 PM
defiant1
Jan 27, 2011 06:47 AM
rockethound
Drivetrain/Differentials
Nov 17, 2006 03:22 PM
