need help decoding this differential
Old Dec 14, 2015 | 07:18 PM
mauricer's Avatar
as far as i know this is a 65 cutlass posi rear diff but can't find any info on the codes i have found on it
M N D or possibly M 1\1 D
Old Dec 15, 2015 | 04:59 AM
monzaz's Avatar
You need to posi pictures of the rear end cover yoke and over whole rear. We need to know what rear your dealing with to look up a code. Thank you, Jim
D is stamped pretty deep I bet it si a 1964 f85 rear 3.55
OR
if it is a 65 then it would go off the M N letter code of 3.08... Hard to say. I would have to say someone goof at the plant with the stamping. Remove the cover and wipe the outer edge of the ring and it should have the tooth count stamped into the ring.
Old Dec 15, 2015 | 05:37 PM
mauricer's Avatar
here are some more pics, it is the one at the bottom of the pics
Old Dec 16, 2015 | 04:41 AM
monzaz's Avatar
rear end
Well it appears to be a 65 rear as the upper control arm bushings are large 2 inch diameter the 64 will be 1" diameter upper control arm bushings. The rear is also a BUICK 10 bolt 8.2 Not the Oldsmobile type.
The Buick 10 bolt was used in all lower HP cars (standard build rear)
Only way your going to tell with this rear is to crack it open and spin the ring wipe the edge until you find the stamping in the edge of it. Jim
Old Dec 16, 2015 | 05:16 AM
scottv442's Avatar
Maintained
OR
X2....it's been 50years since this was made. original gears and posi could be long gone/swapped for something else. Best path is to open the cover and look inside.
Old Dec 17, 2015 | 04:49 PM
mauricer's Avatar
Thanks for the info, I will try and check it out over the holidays
68oldsguy
Drivetrain/Differentials
Apr 25, 2013 07:08 AM
nitrojunkie1029
Jan 27, 2012 06:15 PM
oldsthunder
Aug 28, 2010 12:32 PM
DesertToro
Jan 16, 2007 07:10 PM
new 2 me
Nov 17, 2006 05:23 AM
