72 442/Vista Cruise Rear Axle Difference
VC axle shafts are thicker going towards the wheel bearings. In the O type axles they were flared thicker about midway down the axle shaft because standard axles were breaking. Not sure if the 10 bolts had flared or just thicker axles.
No splines are the same. In O type rears you can not use them in non VC rears because OD of bearing was different. I would assume the same for 71 and up 10 bolts. One of the rearend guys will cjime in. Also the rear drum shoes are 2 1/2" for a VC. You can swap the whole rear brake assembly to a non VC rear to use.
That is about it from the outside that is easy to recognize A10 bearing was used for the wagon being a larger out side and axle shaft diameter...Bit with an untrained eye you will never see it from the outside of the housing.
Jim
ManCutty
Jan 9, 2015 12:08 PM
jensenracing77
Oct 4, 2011 09:18 PM
