Bent axel flange
Old Sep 22, 2015 | 07:23 PM
biggus's Avatar
Bent axel flange
The left rear axel on my 68 Cutlass Supreme 12 bolt BOP has a bent axel flange. Anybody ever try to straiten one, have any luck? Possibly just get another,anybody have one
Old Sep 22, 2015 | 08:36 PM
BackInTheGame's Avatar
Flange?
Are you referring to the plate that retains the axle in the tube? If so, I had one that was wallowed out/bent/chewed up on the inside. I searched and searched, placing Parts Wanted threads, but could not find anyone willing to sell me just the retaining plates. I discovered the ones from a Buick look close, but do not interchange. In the end, I was able to (mostly) repair mine. See the before and after pics below.
Old Sep 22, 2015 | 08:45 PM
biggus's Avatar
No I'm talking about the flange the wheel bolts to, 1/8" out there by the time it gets out to the sidewall it's a fat 3/8"
Old Sep 22, 2015 | 09:46 PM
Yellowstatue's Avatar
Change axles!!!
Old Sep 22, 2015 | 09:49 PM
I'd get a new axle.
Old Sep 22, 2015 | 10:30 PM
svnt442's Avatar
Wait a minute....the sidewall? Are you talking about the axle or the lip on the wheel?
Old Sep 23, 2015 | 05:08 AM
monzaz's Avatar
Straightening axles
Most likely the ability to do this will cost you more than the axle shaft is worth. Buy another used one or New one.
I have both if you need one PM me and will get you prices.
What we need to know is whether your axle is a sealed bearing or a oiled bearing...
Meaing seal in the axle housing tube end or the seal is on the axle shaft outboard the axle bearing. Jim
J D
Old Sep 23, 2015 | 05:11 AM
Octania's Avatar
unless it's the last such axle in the world, get another one
be aware there are variations, the performance ratios [3.42+] have a different spline count. If you have numerically under 3.42, there should be many available for cheap.
Turn the bent wheel a couple lugs and they will cancel each other out
[just kidding, last part]
Old Sep 24, 2015 | 04:39 AM
monzaz's Avatar
w30
Only the w30 w31 models in 67 68 were 31 spline
Very low % that it is that rear. all the rest are 28 spline.
ALL axles can be custom made IF NEEDED. We have all the specs to make alloy custom race axles for the 12 O type rear 28 or 31 spline 57-70 what ever it is.
Need to figure out if the seal is in the axle tube or the seal is ON THE AXLE SHAFT out board the bearing for the correct axle needed. AND yes the spline count.
Jim
JD
jankyrre
Drivetrain/Differentials
Apr 13, 2012 07:37 PM
monzaspyder79
Jan 27, 2010 05:19 PM
D Appeldorn
Jan 7, 2010 11:41 PM
redvettemike
Jun 3, 2009 06:52 PM
kaptmikey
Feb 25, 2009 04:45 PM
