Which spedo-gear?
Old Apr 13, 2017 | 06:35 AM
ben442's Avatar
Which spedo-gear?
68-442, with 391posi rear diff, Muncie trans.
Which speedometer gear should I use? I see different colors associated with different gear count. I'm not sure how to decipher the chart in the assembly manual.
Help please and thanks
Old Apr 13, 2017 | 08:55 AM
This question cannot be answered without knowing the tire diameter (NOT the wheel diameter).
Old Apr 13, 2017 | 09:55 AM
ben442's Avatar
Oh-Ya, whoops forgot to post...
225 70R 14 radial ta, 26.5"
Old Apr 13, 2017 | 10:16 AM
svnt442's Avatar
This is from 1970, but should work. I found the specs on the F78 to be what you're looking for so that line should work, BUT you will have to find the correct adapter to make it work.
This place has the adapters.
https://transmissioncenter.net/?swoo...edometer-gears
rustycragars
Dec 25, 2016 06:06 PM
cycomiko
Drivetrain/Differentials
Aug 27, 2014 01:30 PM
tomc5
May 31, 2014 12:36 PM
tomc5
May 29, 2014 09:50 PM
thomaswatk
Mar 22, 2007 01:31 PM
