Spedo gear
Old Aug 17, 2014 | 06:25 PM
cycomiko's Avatar
Spedo gear
I finally installed the 8.5 rear. Its a 3.73 gear. Which is a huge upgrade from the 2.14 or 2.29 peg leg that was in there. How can I determine which spedo gear to install. I have a th350 and 14 in tires.
Old Aug 17, 2014 | 06:30 PM
cycomiko's Avatar
225 70 14
Old Aug 17, 2014 | 07:50 PM
4speed455's Avatar
To calibrate the speedo their are two gears at the tranny. One is at the end of the speedo cable the other is on the drive shaft of the tranny. Depending on what rear gears and how tall tour tires are there are a number of combinations of gears to get you close. Try this.
http://www.tciauto.com/tc/speedometer-gear-calculator/
Old Aug 17, 2014 | 09:10 PM
cycomiko's Avatar
Yeah I've seen that. Its all greek to me to a point. i need someone to tell me which ones to buy.
Old Aug 18, 2014 | 03:02 AM
don71's Avatar
same but different
You/we need to know what drive gear do you have now? How many teeth on it? After you know this, its pretty easy.
Old Aug 18, 2014 | 06:18 AM
rjohnson442's Avatar
Mr. Johnson
If you don't want to mess with the gears they sell an adapter that goes on the outside of the trans between the cable and housing. The spedo will be off by a percentage and can be checked with a GPS. Then all you have to do is order the adaptorby the percentage it's off by and it will correct for it. Can't remember the company but sure someone will chime in soon though for ya.
Old Aug 20, 2014 | 04:10 AM
jpc647's Avatar
Year and model of the car would help. There are charts in the service manuals, depending on the transmission/rear end your car originally came with.
Old Aug 20, 2014 | 08:58 AM
cycomiko's Avatar
Its a 1980 Cutlass Supreme
Old Aug 20, 2014 | 09:52 AM
cycomiko's Avatar
The old rear was a 6AH rear = 2.29
Old Aug 27, 2014 | 09:56 AM
cycomiko's Avatar
Ok My speedo gear is a brown 18. Trying to peek in the side of the tranny while under the car and count the drive gear was really a PITA. It looked like a tan or neutral color 8 or 9. Per gps when im going 50 my speedo shows 70mph. Also my speedo housing is the small bullet shaped one. Will this work for a bigger gear and which gear or gears should I buy?
Old Aug 27, 2014 | 01:30 PM
4speed455's Avatar
I would just call these guys and tell them what you have and they will tell you what is available to get you where you need to be.
http://www.transmissioncenter.net/sp...____va.htm#350
tomc5
May 31, 2014 12:36 PM
tomc5
May 29, 2014 09:50 PM
drjr56
Sep 9, 2012 08:05 PM
Chuck C
Drivetrain/Differentials
Sep 5, 2007 02:35 PM
70Supreme
Aug 19, 2003 04:24 AM
