67 442 gears
Old Oct 16, 2015 | 07:45 AM
sammieolds's Avatar
67 442 gears
Hi guys I was thinking of putting 322 gears in my car is that a good crusing gear,
There's 373 gears now cars is a 4 Speed
Steve
Old Oct 16, 2015 | 08:01 AM
svnt442's Avatar
Steve
Eh? It should have an O axle in it and 3.73 gears are not made for that.
Old Oct 16, 2015 | 08:45 AM
sammieolds's Avatar
There is a 373 gear in it now from a Chevy 12 bolt the housing says GM57
I trying to make it more drivable for better mileage etc when your in 4th it feels like it needs a 5th gear
With out changing tranny
Steve
Old Oct 16, 2015 | 09:34 AM
svnt442's Avatar
If you have room it would be easier to go with a taller tire for street cruising.
3.23 gears are not made for the 12 bolt, but you can get 3.31's instead.
Here are what you're looking at for RPM changes with a couple of different gear/tire combos:
Old Oct 16, 2015 | 09:39 AM
svnt442's Avatar
I guess what you have to figure out is if it is worth it for a 350 RPM drop at 65 mph to swap out your gears. You're probably going to want to install new wheel bearing while you;re at it and a complete install kit that comes with carrier bearings and pinion bearings. And then if you don't do it yourself there is all the labor involved. My guess would be over $1000 when all is said and done.
Personally I'd leave it be. It's not like it's your every day driver, is it?
Old Oct 16, 2015 | 11:03 AM
sammieolds's Avatar
Yes I hear you I got 15" 70s I believe not much room back there
So a 323 gear won't fit in a 12 bolt Chevy I better let the guy no I think he already ordered them
Old Oct 16, 2015 | 11:14 AM
svnt442's Avatar
Nobody makes them.
Old Oct 16, 2015 | 11:18 AM
sammieolds's Avatar
Ok thanks
Old Oct 16, 2015 | 11:37 AM
lemoldsnut's Avatar
For Chevy 12 bolts it would be 3:31 is about the closest. In addition to all the prior info which is great. Which trans do you have? If is it a M21 then it is a close ratio trans and an M20 is wide ratio. Close ratio would be a little weaker off the line with the 3:31 gear set than the wide but final drive is 1;1 in each.
Jonathon black67442 on here just did a 3:90 to 3:23 and went from an M21 to an M20 and is very happy with it.
Just some input
Larry
Old Oct 16, 2015 | 11:41 AM
wr1970's Avatar
Who sell a new 331 gear package? To the op why not use a 308 gear set up in the 12 bolt chevy rear end!!
Old Oct 16, 2015 | 11:58 AM
sammieolds's Avatar
Its a close ratio m21
Larry did you sell your car
Steve
Old Oct 16, 2015 | 01:17 PM
lemoldsnut's Avatar
Still have it
Got close but no money in my hand as of yet
boc23
Drivetrain/Differentials
Aug 29, 2014 02:23 PM
monzaz
Aug 7, 2014 11:12 AM
oldspackrat
Apr 9, 2013 09:27 PM
RandyS
Oct 4, 2012 03:39 PM
monzaz
May 29, 2010 08:46 PM
