Drive shaft
Drive shaft
Hey guys,
I currently have a 1971 442. When I got the car about a year ago if came with a th350. I lucked into a th400 soon after I got it then got really lucky and found an m20. Well needles to say I'm converting the car from column shift auto to 4 speed but going to need a longer drive shaft. Is there any place that sells them or am I going to have to make one? Any info would be greatly appreciated.
Do you still have your TH350 driveshaft? I've not set the two side by side but have been told the TH350 and 4 speed drivelines were the same. If someone knows for sure hopefully they'll speak up.
John
John
All 1964-72 GM manual transmissions are the same length as the TH350 and ST300 automatics. The driveshafts are the same length (for a given application and wheel base). Note that 4spd driveshafts were usually one-piece tubes whereas the automatic driveshafts were two concentric tubes with rubber isolators between them. These will work on a manual trans, but you may want a solid driveshaft anyway.
Thanks for all input guys, I do still have my driveshaft for the th350 but sounds like I will have one made. I'm just happy to hear I don't have to track an original one down! This group has helped me out a lot kudos to who started this and everyone who shares.
