Drive shaft
Old Oct 17, 2015 | 06:59 PM
bigblockchris's Avatar
Drive shaft
Hey guys,
I currently have a 1971 442. When I got the car about a year ago if came with a th350. I lucked into a th400 soon after I got it then got really lucky and found an m20. Well needles to say I'm converting the car from column shift auto to 4 speed but going to need a longer drive shaft. Is there any place that sells them or am I going to have to make one? Any info would be greatly appreciated.
Old Oct 17, 2015 | 08:37 PM
svnt442's Avatar
Best bet would be to find a driveline shop and have one made.
Old Oct 18, 2015 | 05:51 AM
wr1970's Avatar
Originally Posted by svnt442
best bet would be to find a driveline shop and have one made.
x2
Old Oct 18, 2015 | 06:38 AM
When I had 1 made for my car it was about $300 balanced with u joints.
Old Oct 18, 2015 | 06:47 AM
svnt442's Avatar
That sound like what I paid for mine.
Old Oct 18, 2015 | 06:49 AM
I forgot to add, I supplied the correct yoke.
Old Oct 18, 2015 | 07:33 AM
2blu442's Avatar
Do you still have your TH350 driveshaft? I've not set the two side by side but have been told the TH350 and 4 speed drivelines were the same. If someone knows for sure hopefully they'll speak up.
John
Old Oct 18, 2015 | 07:55 AM
John
All 1964-72 GM manual transmissions are the same length as the TH350 and ST300 automatics. The driveshafts are the same length (for a given application and wheel base). Note that 4spd driveshafts were usually one-piece tubes whereas the automatic driveshafts were two concentric tubes with rubber isolators between them. These will work on a manual trans, but you may want a solid driveshaft anyway.
Old Oct 18, 2015 | 10:58 AM
Thanks for all input guys, I do still have my driveshaft for the th350 but sounds like I will have one made. I'm just happy to hear I don't have to track an original one down! This group has helped me out a lot kudos to who started this and everyone who shares.
Frogge467
Mar 24, 2012 11:09 PM
egknz
Drivetrain/Differentials
May 15, 2011 07:30 PM
64 CUTLASS KEN
Nov 22, 2010 05:17 PM
rose
Feb 24, 2009 10:42 AM
68conv455
Apr 11, 2008 11:48 PM
