Replacement 72 cutlass 10 bolt bolt in axles?
Old Sep 11, 2017 | 06:47 AM
raxefab72's Avatar
I've called a few companies and no one seems to understand what I'm looking for since it isn't a ford 9" or a ch@vy axle!!!
Old Sep 11, 2017 | 07:18 AM
RetroRanger's Avatar
72 Olds CS
contact monzaz on this site he knows olds rearends.
Old Sep 11, 2017 | 07:28 AM
Tiha's Avatar
Jim alias Monzaz has his own site with lot of info and his own FORUM...really helpful guy.
http://www.jdrace.com/
BUT
we have our own OLDS "rear and guy" here
507OLDS alias Brian Trick
thetrickfamily@yahoo.com
Old Sep 11, 2017 | 12:02 PM
BUT
nope, Brian hasn't been on this site since 2014. Stick with Jim Mitschke aka monzaz
Old Sep 11, 2017 | 12:45 PM
Kennybill's Avatar
Sounds like a 1971/ 72 corporate 8.5 ten bolt cover bolt in axles and the cover has a "slash" upper right hand corner \ but more angle. Summit Racing has pictures of the different covers and after you pull your axles count the splines and measure.
Old Sep 11, 2017 | 02:09 PM
10 bolt corporate should be 28 spline
Old Sep 13, 2017 | 09:19 PM
monzaz's Avatar
BIA 10 bolt 8.5 rear
So what is it your looking for?
Axle shafts?
I have good used axles also from when we do 30 spline swap outs in the 8.5 BIA rears.
We have them if you need. Yukon 1541 28 spline axle 29.75 long with the oiled bearing system... set9 bearing 712146 seal
Brian is on the Buick site.
I try to visit all GM car sites to answer questions...IT is a large task and usually can only answer VERY late at night. trying hard to keep intouch you can also PM Call or try the JDRACEsite too.
Jim
J D Race
Old Oct 8, 2017 | 03:00 PM
Racer24ksi's Avatar
Axle shafts?
I went to Cruisin' the Coast this week with our 71 Cutlass. My son was following me and saw that the driver's side rear wheel wasn't rolling normally. I jacked up the car and see now that it looks like I've got a bent axle, which explains a handful of problems that we've been having: a wheel vibration we couldn't balance, premature wearing of brake pads, a pulsing pedal, and pads that won't stay in adjustment. It looks like both are bouncing around a little, but the driver's is the worst of the two. I know it's not the tires or wheels because I've watched them rotate on the balance machine and they're true. The car was rear ended before I bought it and restored it, so I guess the axles took a little bit of a jolt.
I've looked on line and can't find replacements that I can be sure are the right part. Mine are 28 spline, 29 1/2" long, press-bearing without c-clips.
I saw reviews of the Yukon part and there are numerous complaints about the length and bearing fit.
I'm open to used replacements.
Suggestions?
Thanks for helping!
Bill
Old Oct 9, 2017 | 10:33 AM
monzaz's Avatar
PM on axle shafts.
We got them.... Just need to make certain you have a 10 bolt 8.5 under your car. Jim
t_huth21
Jun 1, 2016 09:56 PM
yankees
Jun 13, 2013 03:16 PM
yankees
Drivetrain/Differentials
Jun 11, 2013 06:24 AM
72442conv
Mar 19, 2012 07:14 AM
monzaz
Mar 3, 2011 06:08 AM
