Replacement 72 cutlass 10 bolt bolt in axles?
Jim alias Monzaz has his own site with lot of info and his own FORUM...really helpful guy.
http://www.jdrace.com/
BUT
we have our own OLDS "rear and guy" here
507OLDS alias Brian Trick
thetrickfamily@yahoo.com
BUT
BUT
BUT
Sounds like a 1971/ 72 corporate 8.5 ten bolt cover bolt in axles and the cover has a "slash" upper right hand corner \ but more angle. Summit Racing has pictures of the different covers and after you pull your axles count the splines and measure.
BIA 10 bolt 8.5 rear
So what is it your looking for?
Axle shafts?
I have good used axles also from when we do 30 spline swap outs in the 8.5 BIA rears.
We have them if you need. Yukon 1541 28 spline axle 29.75 long with the oiled bearing system... set9 bearing 712146 seal
Brian is on the Buick site.
I try to visit all GM car sites to answer questions...IT is a large task and usually can only answer VERY late at night. trying hard to keep intouch you can also PM Call or try the JDRACEsite too.
Jim
J D Race
Axle shafts?
Jim
J D Race
I've looked on line and can't find replacements that I can be sure are the right part. Mine are 28 spline, 29 1/2" long, press-bearing without c-clips.
I saw reviews of the Yukon part and there are numerous complaints about the length and bearing fit.
I'm open to used replacements.
Suggestions?
Thanks for helping!
Bill
yankees
Drivetrain/Differentials
Jun 11, 2013 06:24 AM
72442conv
Mar 19, 2012 07:14 AM
monzaz
Mar 3, 2011 06:08 AM
Jim
