1966 jetstar88 oldsmobile.
Old Jun 29, 2015 | 02:06 PM
bigbog442's Avatar
I need to find out what rear end I have exactly does any one know? Also does any one know where I can get good parts for the car other than a junk yard?
Old Jun 29, 2015 | 02:39 PM
I didn't know about the rear end either, but my friends at Google tell me it's a 3.23 (per the Classic Car Database). No other ratio is listed so this is most likely the one although there could be options, I guess. One way to confirm is the old standby method of putting the rear up on jackstands and counting wheel rotations vs. driveshaft rotations.
With regard to parts, you picked the perfect place to start. If nobody on CO has them (or knows where to get them) then they likely don't exist!
Welcome to the site, and best of luck with your Olds!
Old Jun 29, 2015 | 03:29 PM
Welcome to the site, I moved your post to this section to help you get the info you require. Post a proper intro in the newbie section and for gods sake add some pictures, we're gonna ask.
Old Aug 16, 2015 | 07:14 PM
copper128's Avatar
Lt. Buzzkill (ret.)
A 66 Jetstar 88 (330) with automatic trans should have a 2.78 P-type 8.2" 10 bolt.
Optional ratios would be 3.08 or 3.23.
Posi differentials, ring & pinion sets, bearings and parts are readily available for that rear.
Old Aug 18, 2015 | 07:19 PM
monzaz's Avatar
stock
NOW that is all if the car is still ALL FACTORY. Most cars by now have been fix repair wreck restored raced etc.
PLEASE send pictures o f the rear cover area and any casting numbers you can find in the webbing or axle tube etc. Jim
J D
Old Aug 19, 2015 | 08:28 AM
Oldsmaniac's Avatar
The 66 Jstar shares all body parts with the 88 series and some sfire parts and some 98 parts. Trim will vary. The junkyard or used are pretty much your only option. As for mechanical parts there should not be a problem....
radioburningchrome
Dec 11, 2013 05:22 PM
m455sx
Jan 5, 2013 07:50 AM
ajschirling
Sep 20, 2012 07:32 PM
Curth
Mar 24, 2010 04:54 AM
wiseguy58
Feb 11, 2010 01:34 PM
