Slip Yoke Lube Questions
Old Jun 19, 2017 | 06:06 PM
Toms cutlass's Avatar
I replaced the slip yoke and u-joint on the TH350 (with one that doesn't have the weep hole - which inevitably leaks). While I had the tail housing off, I replaced the bushing and rear seal as well. What type lube should be applied to the outer surface of the slip yoke and to the output shaft/yoke splines before re-assembly? Thanks.
Old Jun 19, 2017 | 07:17 PM
I just use a very light coat of grease.
Old Jun 19, 2017 | 07:46 PM
tru-blue 442's Avatar
Old School Olds
+2
Old Jun 19, 2017 | 08:58 PM
Thanks again.
Old Jun 19, 2017 | 10:13 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Trans fluid is the only lube to use in and around an automatic. Grease can wick in from the tail shaft and contaminate the trans fluid. The frictions, steels and seals don't like grease. Petroleum jelly can be used to hold check ***** and seal springs in place but that's the only other petroleum product an automatic trans should see.
Old Jun 20, 2017 | 05:46 AM
^^^This.
The reality is that as soon as you start driving, ATF splashes around inside the trans and lubricates that seal anyway. A light film of ATF at installation prevents a dry startup.
Old Jun 20, 2017 | 07:20 AM
I remember using petroleum jelly back in the day on the slip yoke/rear seal. I'll use only A/T fluid now rather than risk contamination. Thank you for the follow-on replies.
boese1978
Feb 14, 2014 10:56 AM
EKi
Drivetrain/Differentials
Jun 12, 2010 05:47 AM
EKi
Jun 11, 2010 04:06 PM
Lady72nRob71
Mar 12, 2008 05:31 AM
jeffs 89 cutlass salon
Oct 19, 2007 08:42 AM
