rear end info
Old Oct 13, 2014 | 07:21 PM
marsman's Avatar
rear end info
rather spend time & money on 57-58 P/O 9.3 then my 56 unit. can any one tell me if 57-58 rr will fit in my 56 88 post, drum to drum width first,&second perch to perch? with exception to driveshaft &u-joint mods. I believe 59 & later are to wide espec. pont. +leaf to coil mounts may differ any imput would be greatly appreciated!
Old Oct 13, 2014 | 09:30 PM
2blu442's Avatar
Sorry, I can't answer your question. But if nobody replies to this post with an answer contact a member named monzaz. Jim is a resident expert with rear differentials.
John
Old Oct 13, 2014 | 10:39 PM
59-59-59's Avatar
If your looking for specs for this rear, go to fabcraft metalworks. They just put out a good '57-'64 Pontiac/Olds rear end guide with measurements and other info about them. It might be a good investment before you jump into the swap
Old Oct 14, 2014 | 04:41 PM
marsman's Avatar
57-64 p/o 9.3
thanks 59, just got the bible (57-64 P/O 9.3) from fabcraft pretty cool & informitive but does not have housing dimensions.
Old Nov 9, 2014 | 06:24 PM
Charly9g's Avatar
Hi Marsman. Sorry i'm a little late w/the dimensions i promised. I will have the rear-end width dimensions from my '57 olds tomorrow and will post. Things have just gotten in the way. Bill. WFG4U@aol.com.
Old Nov 9, 2014 | 08:05 PM
monzaz's Avatar
Olds Pontiac
Olds 57 58 are the narrowest of the Gasser rears.
Ponitac was always slightly wider... WIDE track commercial stuff.
29.25 was the shortest of the axle shafts. so x2 by 2 and ad about 1" and you will get a usable width.
58.5 + 1" 59.5 about the width of a 67-69 camaro or Nova 68-72
Jim
J D Race
Old Nov 10, 2014 | 10:30 AM
Charly9g's Avatar
"57 Dimensions
Hi Marsman. Just measured my '57 olds rear end. Housing Flanges are 54 1/4" w/o backing plates or anything attached. Overall width with axles, drums, backing plates, etc. is 59 1/4" overall measured from the outside of the drums. Hope this helps. Good luck.
350TurBRO
Sep 12, 2014 11:52 AM
MDchanic
31
Aug 12, 2012 04:24 AM
sx455raidercelticfan
Aug 1, 2010 08:03 PM
viper771
May 31, 2010 12:40 PM
steve19
Dec 31, 2008 11:08 AM
