Stock Olds 10 bolt 8.2" cone LSD (posi) bottom of cone to case clearance question
so i'm starting my 10 bolt 8.2 differential overhaul in my 65 442. i removed the original anti slip lsd differential carrier from the rearend housing last night. i took apart the case, cleaned & inspected all the parts & its time for reassembly. i do have some questions on clearance & such. there is some light scoring on the inside halves of the case & more scoring where the bottom of the side gear & the inner portion of the cone touch. from what i've read in the csm it is normal from debris that gets trapped inside the case itself. the csm also states that the lsd carrier is good as long as the cones don't bottom out on the bottom of the case. luckily mine hasn't but i decided to plastigauge the clearances just to see how close i am. the closest measurement i took was .018" from the machined surface center of the cone to the smooth machined surface sticking up through the center of the case... NOT the machined surface on the bottom of the case (since that dimension was significantly more) please see my pic for reference.
1) .018" doesn't seem like very much. is this lsd case worth reusing?
2) anyone know what the clearance dimensions are on theses cone type posi cases when they are new?
thanks in advance
thanks in advance
I don't know the answers to your questions but I do know that a worn cone diff can be machined to bring it back into a functional state. My brother in law had the cone posi in his '68 GTO done back in the late 80s. I think it entailed machining the end of the cone so it would have more end clearance and the cones would grab the walls. Anyway, just a bit of info so you are aware these actually can be rebuilt.
pOSI UNIT RECONDITIONING
I do the reconditioning here in Ohio... Akron area.
.050 -.100 is about a guess NEW. Your getting close to having a bottom out in the carrier. one more summer of winding roads and that unit will be toast.
Jim
Do not forget about the cone outer diameter too. Jim
JimDo not forget about the cone outer diameter too. Jim
I have an 10 bolt 8.2 for sale.
Eaton posi diff
Richmond 3:55 gears
TA Performance girdle/diff cover
New brakes
Needs drums and brake lines
Other than that it's ready to install and run
Has less than 1000 miles
Eaton posi diff
Richmond 3:55 gears
New brakes
1966 Cutlass Vert
Wayne
Medina, Ohio
rebuild
anyway... posi gear setup narrowing etc.
pm will get you squared away. Jim
J D
81 regency
Apr 21, 2011 06:18 PM
