1968 SD code rear end- easy to remove posi carrier?
Old Jan 12, 2015 | 06:08 PM
shamusj's Avatar
Gentlemen- please pardon my potentially stupid question. i've never worked on a rear end other than changing fluids.
I picked up a 68 cutlass parts car with an SD code rear end. If i have my facts straight this is a 3.08 posi. I currently have a '68 442 with an s4 single leg 3.08 rear end.
If possible- I'd like to quickly remove what I need to update my car to posi and then send the parts car off to its new owner. What is involved in removing the posi carrier? special tools, pullers, axle removal? Do I need to remove any other parts for the posi swap?
I'll be working in cramped quarters, off site and would like to avoid a major cluster F if possible.
Thanks for any guidance.
Old Jan 12, 2015 | 06:24 PM
dnmfranco's Avatar
I would seek out user name "monzaz"
unfortunately don't have his name but he from what I understand is really knowledgeable re rears
Dean
Old Jan 12, 2015 | 06:25 PM
Eddie Hansen's Avatar
Yes I believe it is a 3.08 posi, why not just swap re ar ends that would be easier imho,
But if you want to take out thecarrier you will need to pull axles , drive shaft yoke , etc, do you have a chasis manual? You might need a slide puller for the axles, were you just planning on bolting the axles into the empty case?
Make sure you keep each sides shims together it will be important
Old Jan 12, 2015 | 06:30 PM
dnmfranco's Avatar
wow, lol or just have Ed help you
Ed that's great your versatile in rears, me not so much
Old Jan 12, 2015 | 06:49 PM
Dean, I rebuilt my 3.08 posi awhile back, it was my first time and yes monzaz is the man hes at jdrace www.jdrace.com, that is where I bought the clutches bearings etc if shamusj is interested I did document the build in my resto thread but definately jim is the man..
Old Jan 12, 2015 | 06:55 PM
Octania's Avatar
It is possible but frankly you would be better off to swap the entire assembly. Spacers matter, gear contact pattern matters... why mess with that?
Old Jan 12, 2015 | 07:19 PM
tru-blue 442's Avatar
Old School Olds
Agree with above, just swap them out. It isn't that hard a job with a helper
and a few cold ones.
Old Jan 12, 2015 | 09:32 PM
shamusj's Avatar
Got it- thanks for setting me straight. I'll pull the entire rear end monster and sell the body shell as a crippled non roller.
Thanks for keeping me out of trouble- spacers, teeth alignment….definitely not to be messed with.
Old Jan 13, 2015 | 05:51 AM
Old Jan 13, 2015 | 07:02 AM
stan 65 cutlass's Avatar
just roll yours right back under it, some quick bolts and its still a roller
Old Jan 13, 2015 | 10:50 AM
Stan, there is the Brake union, not sure the conditions of the OP's drums, Wheel Cylinders Brakes, bushings, etc, But that is how I would approach it as well...
On that note; Shamusj, it would be the time to change all those items or at least inspect,
I changed all the bushings in the upper and lower control arms, the axle seals, bearings, pinion seal, springs, shocks, isolators... etc you will never have a better chance.
if you look at the first few pages of my build thread I believe most of the work has been detailed
https://classicoldsmobile.com/forums...ertible-1.html
Old Jan 14, 2015 | 12:34 PM
Octania's Avatar
it is also possible to pull the axles
loosen the brake assemblies including backing plate
unhook brake lines from the differential
leave the brakes undisturbed and on the car
swap out rear end assembly
If rust is an issue where you live, the bolts can be rusted tight in the center sleeve of the control arm bushings and give trouble. cut them off if need be.
Bob Kelso
Mar 21, 2014 03:35 PM
RALLYE KID
Dec 20, 2013 11:58 PM
MDchanic
31
Aug 12, 2012 04:24 AM
costpenn
Drivetrain/Differentials
Sep 16, 2011 11:08 AM
muad
Jan 19, 2009 03:55 PM
