71 Cutlass 12 bolt axle question
Old Sep 22, 2017 | 07:20 PM
shockrebuild's Avatar
I have a 12 bolt rear out of 71 cutlass that my rear drivers side axle broke. Its a 28 spline does anyone know where to get a replacement? Is a 10 bolt rear drivers axle the same?
Old Sep 22, 2017 | 08:31 PM
oldspackrat's Avatar
A '71 Cutlass came from the factory with a 10 bolt cover & a 10 bolt ring gear. If your car has a 12 bolt cover & a 10 bolt ring gear, it may be an Oldsmobile rear end but you need to know for sure before you start buying parts. Can you post a picture of your cover & any letters on the side of the differential along with pictures of the ribs on the sides of it. I have a 12 bolt Olds. rearend that I just pulled an axle out of for another guy. If it is indeed an Olds. rear end that you have, I may have an axle for you.
I "think" the axles are the same as far as 10 or 12 bolt, assuming they both have 28 splines.
Old Sep 23, 2017 | 07:41 AM
They are very close but do not interchange (I tried and it didn't work). The splines are different and the shaft will not insert into the carrier side gears.
Old Sep 26, 2017 | 08:10 PM
monzaz's Avatar
We have replacement axles for 129.00 28 spline for sealed or oiled bearing axles
1970 is usually oiled bearing
1967-1969 is normally sealed bearing axle.
You do need to know which one you have before ordering.
Studs new are 1.15 each installed.
Jim
J D
pontiac1
Drivetrain/Differentials
28
Feb 19, 2022 10:07 AM
RROLDSX
Jul 24, 2013 10:12 PM
raw442
Jun 2, 2013 04:08 PM
72442conv
Mar 19, 2012 07:14 AM
cutlasssupreme71
Feb 22, 2011 11:40 AM
