1970 Cutlass S 'vert
Old Jan 12, 2016 | 08:52 AM
dawgdays's Avatar
Sadly, I need to sell my 1970 Cutlass Convertible that I have had since HS graduation in 1985.
Working on a few maintenance items to get max dollar including a diff oil change.
I have some royal purple Max-Gear Synthetic Gear Lube Oil 75W90 left over. Can I use the syn stuff in this diff?
It is NOT a posi rear.
Do I need to add the LSD additive?
Old Jan 12, 2016 | 09:45 AM
RROLDSX's Avatar
If it's GL-5 or better it should be fine. You do not need the additive. It is meant for posi.
Old Jan 12, 2016 | 11:51 AM
dawgdays's Avatar
From the Royal Purple website...
Max Gear is recommended for use in truck and automotive front or rear differentials, manual transmissions and lower gear units of marine engines that specify use of an API GL-5 or GL-4 fluid. It is non-corrosive to soft yellow metals (brass, bronze, copper, etc.) and synchronizer safe. Specially designed to extend gear and bearing life, Max Gear provides superior corrosion protection over competing conventional and synthetic gear oils.
Old Jan 12, 2016 | 02:47 PM
Diego's Avatar
For what it's worth, it's a Cutlass Supreme, not a Cutlass S.
halfmoontrail
Mar 17, 2013 10:28 AM
Ken'sConvertible
Aug 5, 2012 07:43 PM
smietana
Feb 17, 2012 02:13 PM
1970442Canada
Dec 16, 2010 07:47 PM
1970442Canada
Sep 23, 2009 02:06 PM
