10 Bolt. 2.73
Old Oct 19, 2017 | 01:27 PM
sammieolds's Avatar
10 Bolt. 2.73
Hi Everyone
My 74 Oldsmobile C S, 350 K motor 180hp?
I’m trying to wake it up a little would changing the rear end to a 3.43 help it
Take off better
What other recommendations would you guy do
Thank
Steve
Old Oct 19, 2017 | 01:32 PM
Swapping the rear gears is the easiest and most effective performance gain you can do.
Old Oct 19, 2017 | 02:23 PM
oldsmobiledave's Avatar
money well spent
Your biggest bang for the buck will be dual exhaust, headers & a rear gear change. Consider 3.23s if you are staying with the three speed automatic.
Old Oct 19, 2017 | 04:05 PM
sammieolds's Avatar
Thank guys
Old Oct 26, 2017 | 07:51 PM
monzaz's Avatar
things to check first
Before buying anything....
how many miles are on the motor?
if your looking to just burn rubber a higher stall converter makes nice snap even with freeway gears.
ALL this is moot if the cart has a carb or ignition not correctly set.
Just because the car starts and idles and runs does not mean that it is correct.
advance in the distributor could be all messed up advance curve carb float dumping too much fuel will kill torque and power etc.
There are many things to check before assuming the car just does not have the power and needs gearing.
The cars back in the day were more than capable to tear up the ground with 2.73 gears stock from the factory...So if it is not doing that you are just band aiding an old tired motor and parts that should be repaired.
200 -2500 stall on a well tuned 2.73 3.08 geared car will go very well with out losing freeway comfortable driving.
As stated once you get to 3.55 you will loose the freeway comfort...noise vibrations RPM noise unbalance motor shake at more rpms will occur ... It is not a new car and more RPMS will certainly bring out all the imperfections in the ride.
Good luck on the choices... make sure you have done everything you can with the parts you have now before spending more. timing, advance, carb adjustment, check the spark plugs for burn and see if one cylinder has a different plug burn residue ....
Jim
J D
Old Oct 27, 2017 | 06:28 AM
sammieolds's Avatar
Thanks for the advice JD
tmcfall
May 29, 2024 12:41 PM
tru-blue 442
Drivetrain/Differentials
May 7, 2012 08:48 AM
72442conv
Mar 19, 2012 07:14 AM
olds4life
Oct 5, 2010 05:18 AM
dman0712
Mar 16, 2010 07:40 PM
