1953 88
Old Dec 21, 2015 | 02:23 PM
drolds53's Avatar
Red face 1953 88
need assistance in removing rear drive shaft--way different than my 442--got bolts off can get driveshaft to drop --also need rear pinon seal replaced and trans rear seal --any pics would help--not sure if this has olds tranny or buick due to the fire at hydomatic plant
Old Dec 23, 2015 | 06:49 AM
monzaz's Avatar
?? It does not have u bolts at the yoke? Pretty sure I remember this year having u-bolts holding the u-joint on a almost flat yoke with just a shallow saddle. Pry it off after you get the u-bolts off with a big screw driver between the nut head and u-joint. If the system is older, then your going to have to post pictures. Jim
I will try to look up a seal number. I am sure there are guys here with books that might be faster than me. Jim
J D
Old Dec 23, 2015 | 08:20 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I kind of think the 53 had straps across the universal joint that bolt to the yoke on the differential. If not it has u-bolts. In either event, remove those and then take a large screwdriver or pry bar and put between the universal joint and the differential and pry against the ujoint. it should come loose.
Old Dec 23, 2015 | 08:34 AM
Tedd Thompson's Avatar
If you have more than two speeds it's a Hydra-matic. The Buick Dinaflow in all models was only a two speed transmission.... Tedd
olds53rocket
Dec 22, 2006 05:46 PM
classicdreamcars
Cars Wanted
Apr 18, 2006 03:50 PM
<jdhideaway@aol.com>
Brakes/Hydraulic Systems
Mar 31, 2005 08:15 PM
AC
Feb 7, 2005 04:13 PM
jim braith
Jan 2, 2005 05:46 PM
