Driveline vibration
Old Jun 8, 2015 | 08:25 AM
jtdb153's Avatar
Driveline vibration
I have a Rallye 350 4 speed and I have been trying to diagnose a vibration issue, the vibration only happens when the car is in gear. I had a new rear axle installed and I was told that the pinion angle could cause a vibration,and another person told me it could be a bad rear tranny bearing among other possible causes.
Any thoughts would be appreciated Thanks
Old Jun 8, 2015 | 08:52 AM
70cutty's Avatar
Beer Connoisseur
On one of my cars the driveshaft started coming apart due to the rubber between 2 pieces being worn out, started vibrating pretty bad. Ended up having a 1 piece driveshaft made.
You may need your's rebalanced.
Old Jun 8, 2015 | 09:05 AM
Is there a particular speed that its happening? Does the vibration increase or decrease with speed? Are there any funny noises associated with the vibration? Does it go away when you push in the clutch? Is it present in all gears?
Old Jun 8, 2015 | 01:02 PM
jtdb153's Avatar
It happens in all speeds but does decrease in forth gear(60mph). There is a funny noise and the only way I know how to explain is that it sounds like a Whrrrr sound coming from under the dash area. The sound goes away when the car is in neutral,but while in neutral if I press the gas pedal the noise can be heard. If I press the clutch in the noise does slightly go away.
Old Jun 8, 2015 | 01:57 PM
You said its at all speeds, but decrease in 4th @60
Does the vibration increase or decrease with speed? Is there a rhythmic or harmonic note to it, like tire balance?
You said there is a whirring noise from under the dash and goes away when you push in the clutch and more pronounced when you give it gas.
Does the vibration go away when you push in the clutch?
Please answer the remaining questions. If your transmission is an M21 then it will have a whine to it 1st thru third and somewhat disappear in 4th.
Old Jun 8, 2015 | 06:50 PM
jtdb153's Avatar
It's a M21, the noise was never in the car until I had the new rear installed
and engine broken down for restoration
Old Jun 8, 2015 | 07:15 PM
steverw's Avatar
I believe the driveshaft has to be indexed correctly. Not the correct term i know but I forgot what its called. It can be 180 degrees out, rear U joints must be alligned correctly. Engine broken down for restoration?, possibly a bad clutch disc/ pressure plate, was it balanced? And all balanced together at the same shop? I had a clutch builder, do the pressure plate and disc for my Vette, supposedly balanced. Long story short the car shook so violently, it was like an over grown vibrator. Took it to the shop that did the engine, found it to be 55 grams out of balance! New pressue plate and clutch disc neutrally balanced and all was good.
Old Jun 8, 2015 | 07:38 PM
Your going to have to try and eliminate the possibilities one by one.
Old Jun 8, 2015 | 11:19 PM
rustyroger's Avatar
'87 Delta 88 Royale
Possibly you have a bad layshaft bearing. All power is sent via the layshaft except in top gear.
But check first the driveshaft is properly aligned and balance weights haven't fallen of it.
Roger.
Old Jun 9, 2015 | 04:14 AM
jtdb153's Avatar
Thanks guys for your help!
Olds luvr
Oct 25, 2018 09:14 AM
4-Speed
Mar 30, 2011 11:20 AM
trackz man
Mar 25, 2011 12:47 PM
D.Mac
Jun 14, 2010 05:38 AM
club442
Jul 10, 2009 05:25 PM
