PDA
View Full Version : Toronado
Pages : [1] 2 3 4 5
  1. 68RocketAction recognition
  2. 1966 to 1970 Oldsmobile Toronado Electrical Wiring Diagrams
  3. Caliente Digital Dash Repair Solution
  4. Wiring diagram questions
  5. Comfortron question
  6. Green signal light lenses
  7. Shunt splice and wire size
  8. Saw a ‘66 Toronado at a show this morning!
  9. Wiring diagrams
  10. Trofeo in the Wild
  11. Exhaust question
  12. Another question
  13. Questions about configuration
  14. 1967 Toronado Power Brake Booster
  15. '66 Toronado Exhaust Manifold clearance
  16. 1966 Toronado Brake Drums
  17. 1966 cornering lites info wanted
  18. Inner fender wire straps
  19. GSP Axle Shafts?
  20. '67 Toro Hard Shifting
  21. Testing AC vacuum tanks - '67 Toro
  22. Rear Horizontal Shocks - '66 Toro
  23. 1984 Toronado Wiper Fluid Switch
  24. 66 headlite accent finish
  25. ‘67 Toro trunk trim piece ID
  26. ‘67 Cowl - screen or not?
  27. Odd rim
  28. 67` Toronado - Differential locked possible?
  29. A great opportunity for '66 to '70 Toronado owners in the LA area.
  30. ‘67 ash tray spring install
  31. Fuel Gauge
  32. Toronado gauges
  33. 92 Toro Trofeo AC issue
  34. 1972 Toronado vacuum lines
  35. '67 Toro stereo multiplexer placement
  36. '66 Axle tq values CSM Vs Assy Manual
  37. 1967 Toronado Windshield Wiper Motor
  38. 81 Toronado
  39. Bathtub clips
  40. '66 Toro dashpot PN 392902
  41. '66-'67 Driver/passenger door rear view mirror confusion
  42. 1988 Toro air suspension
  43. '67 Toro Cruise Control thumbwheel repair?
  44. Toronado Resto-Mod
  45. Buying Toronado. How to inspect?
  46. 1968 toronado possibly w34?
  47. Just Some Pics
  48. 1966 Toronado Heater Hose
  49. 1967 vent/heater/AC/defrost buttons won’t stay down
  50. Dropping column, pulling dash cluster.... advice?
  51. Rear brake hose - '66 Toronado
  52. Mystery part
  53. Window Molding Clips
  54. Blower motor
  55. Air Cleaner ID
  56. Tire change - tool storage
  57. Rear seat carpet - '66 Toro
  58. 66 425 engine question
  59. 66 Toro Sparkplug Wire Issue
  60. Is this a 68 toro w34?
  61. '66-'67 Interior body color
  62. Disc Brake conversion from '76 to '66
  63. '66 Quarter Trim removal
  64. '66 interior rear courtesy light panel removal
  65. 1966 Tornado Comfortron question
  66. Toronado Rims
  67. Toro cam specs?
  68. Whats going on with"Sparky"?
  69. 1984 Toronado Air Ride Help
  70. I am missing something between my Master Cylinder and Booster?
  71. Should I buy an 85 tornado?
  72. '66 drivers side mat
  73. 66 Fan Shroud
  74. Toronado jack box
  75. 1968 Toronado Undercoating Location Question
  76. Dipstick and tube
  77. Engine/ trans install
  78. Power Steering Fluid
  79. Pitman arm removal
  80. '66 Telescoping wheel won't lock in place
  81. Toro 67: Removing Harmonic Balancer Nut
  82. Power locks 66 Toro
  83. ‘67 Toro divorced choke coil orientation
  84. Switch pitch, effect on performance?
  85. Showing off the Toro...
  86. Possible ‘66- ‘67 headlight switch replacement?
  87. 1967 Toro Exhaust Replacement
  88. What happened to this rotor?!?!
  89. Use '69 headlight switch on '67 ??
  90. 92 Toro lower front spring insulators
  91. Correct Master Cylinder '67 Toro, power drums
  92. Exhaust size
  93. Are these my original front springs? 92 Trofeo
  94. '67 Toro Drum vs disc brake lines - are they *that* different?
  95. Adding tachometer to replace clock - ‘67 dash
  96. 92 Toro Trofeo engine vac diagram
  97. 67 Toronado not shifting into gear
  98. '67 Toro front shock replacement
  99. ‘68 Toronado restoration
  100. AC recharge, 66 toro, R152a
  101. Ash tray spring
  102. Toronado trunk divider placement
  103. '67 Toro package tray removal
  104. Making jack case for my ‘67 from scratch
  105. '67 Toro 8-track case color?
  106. FwD caddy Toronado Quast.
  107. '66 Toro transmission control switch
  108. Rear speaker size? ‘67 Toro
  109. Sensor on Left intake manifold
  110. '67 Toro cruise control - self rebuild or send it out?
  111. Exhaust Manifold Interchange between 67 and 66 ?
  112. '67 Toro CV replacement boots
  113. 66 Toro horizontal shock question
  114. Engine progress
  115. 1973 oldsmobile toronado 455 a/c problem
  116. '66 Toronado steering gear PN?
  117. Springs on Exhaust Manifold to Pipe Connection
  118. '66 Walkaround
  119. Gasket material for firewall
  120. '66 Inner tie rod ends
  121. 1966 Tornado in Jacksonville
  122. '66 Lower ball joint clearance
  123. 66 Tornado disk brake conversion
  124. 66 front motor mount
  125. ‘67 Toro inner fender color
  126. '66 Leaf spring bushings
  127. Core Plug ("Freeze Plug") Fun 🤬
  128. '67 Toro driver's int handle loose; other door questions
  129. 1966 Trunk paint
  130. '66 Wheel bearing install
  131. 1981 Toronado p/w seats
  132. '67 Toro cam selection
  133. ‘67 Toronado exhaust heat riser spring attachment
  134. 80 Toronado 3 spoke wheel no horn
  135. 67 Toronado Info Parts
  136. Gauge Cluster redo - '67 Toro
  137. Fixed my ‘67 Toro clock
  138. Distributor advance can
  139. Knock knock whos there?
  140. Wiper switch triggers ON too easily - '67 Toro
  141. '66 Headlight switch - aggrivation
  142. '67 Toro battery hold down ?
  143. 66 toro freeze plug
  144. How does one remove headlight bulbs? 66 Toro
  145. Finish question
  146. Heater/AC control TEMP knob removal ? '67 Toro
  147. Outside door mirror installation, '67 Toro
  148. Door conduits and crappy NE wx
  149. 2nd Gen Parts for 1st Gen?
  150. 1988 Toronado front bumper filler needed
  151. Orange wire lead above fuse box - ‘67 Toro
  152. 66 toro carb dashpot
  153. Mounting of metal pipe for heater
  154. 😵‍💫 Front wheel cylinders...
  155. Ammeter Troubleshooting
  156. '67 Toro blower resistor
  157. Dual brake m/c
  158. '67 Toro main vacuum tank and others; headlights
  159. Quadrajet adjustments 66 toro
  160. The saga continues
  161. Remove front engine mount for service?
  162. Alternator wiring ‘67 Toro
  163. Drive axle removal
  164. 66 toro... previous owner syndrome ​​​​​​​😂😂
  165. Wiper blade refills 66 toro?
  166. Brake line leak
  167. 66 Toro Alternator
  168. 66 Toronado Dash Lights
  169. switch pitch linkage
  170. '67 Toronado radio options
  171. Lift & Supporting the 66' Toro
  172. Battery Tray Identification
  173. 1992 Trofeo VIC issue
  174. 66' Toro Drums
  175. 1988 Toronado throttle body coolant pipe.
  176. Steering interchange
  177. 1981 windshield wiper arms
  178. Steering column
  179. 1971 J toro exhaust manifold?
  180. 1966-67 Buick Riviera, Cadillac Eldorado & Oldsmobile Toronado
  181. Defrost hose 1966 Toronado
  182. 1970 GT suspension
  183. 1989 Trofeo Struts, shocks, and springs
  184. trunk lamp switch
  185. 77 Toronado on it's way to me.
  186. 1969 oldsmobile Toronado final drive
  187. Toronado -78 heat/cold problem
  188. 1973 Toronado
  189. 78 Toro parts?
  190. 81 toronado power seats
  191. 1981 Toro engine decals
  192. Wheel bearing squeal?
  193. Toronado racing
  194. 1978 Toronado thermostat housing hose?
  195. Differential ? And video
  196. Lower ball joint replacement
  197. 66" Toronado CV axles
  198. Trying to solve rear bumper wire mess
  199. Inspection findings on my 66' Toronado - could use some advice
  200. 1970 455 W34 Water pump
  201. Steve Magnante - torsion bar suspension
  202. 66 Toro, High rpms/engine straining on highway
  203. 66 Toro vac line questions
  204. 1968 Toronado Gas tank
  205. 1968 Toronado W-34
  206. Jacking points on '69 Toronado?
  207. Radiator Leak in 1977 Toronado XS
  208. Removing drivers side valve cover bracket
  209. 1966 Toronado front & rear shocks upgrade ...
  210. 66 67 dual snorkel air cleaner value ?
  211. Headers for a 1972 Toronado?
  212. 1966 Rear Cowl Removal
  213. Quadrajet Carb repair
  214. Good Source for a Radiator
  215. 1966 Toronado No Heat
  216. 1966 Toronado Late Upshifting and doesn’t down shift
  217. 1966 Toronado Cruise Control Front Wheel Speed Cable
  218. 1978 Olds Toronado XS, what's it worth?
  219. 1978 Toronado XS
  220. What is considered normal vacuum for an toronado 325 engine
  221. 1966 Toronado Cruise Control Dial Removsl
  222. Car was switched from Comfortron to Normal A/C
  223. 2 tiny vacuum hoses under glove box 1966 toronado
  224. 77/78 Toronado alert!
  225. 1966 Headlight Door Disassembly
  226. 66' Toro wiring harness
  227. Releasing Torsion Bar w/o Tools
  228. Help!, Can't remove the left drive axle!
  229. Extracting a Ball Joint!
  230. ‘68 Toronado front wheel bearing.
  231. First time car/classic olds owner. 1973 toronado
  232. Have my eyes on a 1969 Olds Toronado
  233. 1972 Toronado
  234. 1970 grille rocket emblem color
  235. Steering wheel turned to the left
  236. 66 headlight trim rings
  237. Spindle/Knuckle color
  238. 1966 to 1969 Toronado Headlamp Vacuum Diagrams
  239. 84 Toronado ATC Sensor Help
  240. ‘66 Tornado Discussion: Well worth a watch
  241. Steering Column Swap
  242. Comfortron vacuum options
  243. No juice at all to cabin on ‘68 Toronado
  244. Unknown sender on 1968 Toro
  245. 68 – 70 Toronado 455 Radiator
  246. 66 Rear bumper
  247. 66' headlights - newbie vacuum questions
  248. 66 Wiper motor removal
  249. Instrument panel removal - transmission pointer
  250. 1969 Toronado power steering gear seal replacement
