1981 Toro engine decals
Old Jun 29, 2023 | 06:01 PM
dal442's Avatar
quick question
seeking: (1) small air cleaner decal NU "keep your gm vehicle all gm"
(2) decal over top of radiator shroud " gm vehicle emission information" "emission hose routing "
diagram.
(3) black flex plastic hose from end of air cleaner nozzle, to air inlet box next to upper radiator hose.
( my guess 3 inch diameter )
anybody have a source ?
dal442
Old Jul 1, 2023 | 04:42 AM
torotoyguy's Avatar
For decals, try Mark Cornea Reproductions at "drdecal.com"
Good luck.
Old Jul 1, 2023 | 05:24 AM
69HO43's Avatar
He won't have any of those decals most likely because I haven't made any yet. I believe the 81 air cleaner decals had the bar codes on the RH side. Dr. Decal doesn't carry any of the bar coded "Keep your GM car all GM" decals nor the 81 engine emission decals.
For the hose, it's called an ADAPTER, part number 22505347. E body gas engine only. 1981-1985 used the same part. Has a clamp on the front and a plastic bend snap-in part on the air cleaner end side. It's weird because the air cleaner inlet has a downward slope from the air cleaner housing.
Old Jul 1, 2023 | 06:20 AM
jaunty75's Avatar
Mark Cornea doesn't have this. An '81 model is too new. These decal places cater to the mid-70s and earlier models, in my experience.
Old Jul 1, 2023 | 11:11 AM
69HO43's Avatar
Mostly true, but he apparently has no problem "borrowing" others' 80s era decals, that I can tell you.
Just got done making some 70 Vista jacking instructions and stowage decal set for someone. Nobody had these in a complete set either...until now. Plus got some 70 Vista tire presssure door jamb decals in case anyone needs any.
Old Jul 2, 2023 | 04:05 PM
dal442's Avatar
thank you all for the leads---appreciate it
dal442
78Cutlass4Speed
Jun 6, 2022 11:11 AM
sunderlandmorrow
Sep 6, 2021 10:47 AM
tkcutlass
Suspension & Handling
Jun 22, 2021 03:56 PM
rptw32
Dec 25, 2011 07:55 AM
billykissell
Apr 29, 2011 08:34 AM
