2 tiny vacuum hoses under glove box 1966 toronado
Old Jan 7, 2023 | 09:25 PM
Brsharp's Avatar
I come across two very small diameter vacuum lines unhooked tucked behind the glove box, 1966 Toronado
Anyone know what there for ID is about as big as a pencil lead
Randy
Old Jan 8, 2023 | 07:12 AM
Loaded68W34's Avatar
Can you post pics? What color stripes are on the hoses? Does the car have A/C? If so, is it standard or comfortron? Does the car have power locks? A power trunk release? Vacuum lines in that area could be for the vacuum transducer (used on comfortron systems), the inside/ outside air door actuator (used on all A/C systems), other A/C actuators, power trunk release button, or even hoses that fell off the power lock vacuum relay. More information and photos are needed.
Old Jan 8, 2023 | 07:50 AM
Tri-Carb's Avatar
https://www.oldairproducts.com/produ...05-vacuum-hose
Old Jan 8, 2023 | 09:21 AM
I believe he is asking what his lines were connected to, not where to get more vacuum hose.
Old Jan 8, 2023 | 09:35 AM
Oldsguy's Avatar
Past Administrator
My first guess would be for power trunk release.
Old Jan 8, 2023 | 09:44 AM
Tri-Carb's Avatar
Thanks. I see.
Those lines are most likely pneumatic plumbing for cars equipped with a remote trunk release option located in the glove box.
Old Jan 8, 2023 | 11:14 AM
That was one of the many possibilities I suggested in my post, however there are a lot of things that run on vacuum in Toronados.
Old Jan 8, 2023 | 11:30 AM
Brsharp's Avatar
Yes I will post pictures today, the 2 hoses are small about the size of a piece of spaghetti
Old Jan 8, 2023 | 11:50 AM
Tri-Carb's Avatar
The glove box location narrows the possibilities down.
Old Jan 8, 2023 | 11:54 AM
rocketraider's Avatar
Oldsdruid
That sounds smaller than vacuum trunk release.
Is this a Comfortron car? If so does the Comfortron work? There are three Comfortron components in the area of the glovebox. Here's the vacuum diagram from 1966 CSM:
Note that the diagram shows what color stripe is on each hose. Might help identify what it goes to.
Old Jan 8, 2023 | 12:39 PM
Brsharp's Avatar
thanks for the reply No it has the regular push button system with ac
Old Jan 8, 2023 | 01:07 PM
Yes, it narrows the possibilities to all the ones I listed in the second post. The trunk switch is next to the glove box. The comfortron vacuum transducer is mounted on the firewall directly behind the glove box (this has been ruled out since the OP has clarified that his car has regulr A/C). The vacuum relay for the power door locks is mounted in the dash directly above the glovebox. The inside/ outside air door is next to the glovebox behind the kick panel. The other vacuum actuators are mounted on the inside A/C box at various locations behind the dash. Given the description of the size of the hoses, they are probably NOT for the trunk as the trunk switch uses larger (roughly 1/8" ID hoses). The A/C system and power door lock system both use the tiny vacuum hoses described by the OP. While all of the inside A/C vacuum hoses are the small diameter, only those running from the door switches to the relay are small in the power door lock system.
Old Jan 8, 2023 | 01:12 PM
Oldsdruid
OK. Here's the manual A/C vacuum layout:
Probably the lines going to the air inlet diaphram behind the passenger kick panel.
Does the car have vacuum trunk release or door locks? Power trunk vac line routing:
The more we know how the car's equipped the better we can help you.
Old Jan 8, 2023 | 01:57 PM
Brsharp's Avatar
Thanks there are no power door locks
There is a vacuum activate trunk but I found the hose from the trunk and a yelllow striped vacuum supply hose and attached them to the truck release button
The 2 hoses are properly 1/32 to 1/64 id
lamboguy
Sep 21, 2022 09:01 PM
wim lesabre59
Jun 28, 2018 11:12 PM
bw1339
Aug 24, 2016 06:47 PM
Godsrodsjohn
May 28, 2012 10:27 AM
rroth01
Aug 23, 2008 10:06 AM
