Where is the fusebox on a 1966 Toronado?
Old Sep 21, 2022 | 12:10 PM
lamboguy's Avatar
The headlights and heater controls and radio don't work on my 66 Toro.
WHere is the fuse box?
Old Sep 21, 2022 | 01:13 PM
rocketraider's Avatar
Oldsdruid
Left side of car, behind dash on firewall. This is from Toronado section of 1966 Olds Chassis Service Manual.
When you say headlights don't work, do you mean the lamps don't come on or that the doors don't open? Doors are vacuum operated.
Headlight switch power source is from the junction block underhood. The switch then powers the taillights and instrument lamps fuses.
Do you have a 1966 CSM?
Old Sep 21, 2022 | 06:33 PM
lamboguy's Avatar
Thank you very much for the drawing.
Headlights don't come up because the vacuum unit is bad.
Headlights recently don't turn on either - so I started looking for a fuse box.
Old Sep 21, 2022 | 09:01 PM
There is no fuse on the headlight circuit. There is a self-resetting circuit breaker built into the headlight switch.
shiftbyear
Nov 28, 2021 12:39 PM
smietana
Dec 28, 2018 08:48 AM
wim lesabre59
Jun 28, 2018 11:12 PM
jaunty75
Jul 26, 2015 05:15 PM
ed burke
Apr 3, 2015 03:06 PM
