1988 Toro air suspension
Old Jun 6, 2025 | 04:38 AM
JednTori88's Avatar
Originally Posted by BillK
I called one of my customers earlier who has a Riviera like mine and is pretty heavy in the Riviera club. He said that several guys have used this person. Apparently he does complete rebuilds on those systems and sells parts etc.
Joshua Kasprzak
(320) 496-5532
I have been lucky that mine is still working fine after 300k miles Its on its third set of rear shocks. You cant get the GM shocks any more but Monroe has a set that fit with a minor change to the hose fittings. I actually have a spare set of shocks but they are missing the air lines that come with them.
Good day! I would like air springs on my 88 but not sure what would fit. My compressor works at the moment but the shocks won't hold air. Any part numbers for air shocks that would work would ne greatly appreciated.
Old Jun 6, 2025 | 04:51 AM
I moved your post to a new thread. I suggest you use the following search engine to find a Toronado in a salvage yard near you.
http://www.car-part.com/
Old Jun 6, 2025 | 07:41 AM
BillK's Avatar
Had me totally confused because I got an email that someone had replied to the other thread but there was nothing there
Old Jun 6, 2025 | 07:51 AM
BillK's Avatar
Jed,
Make sure it isnt the air lines leaking. You can spray some Windex or other soap on the fittings to check. It looks like the original shocks have long been discontinued. I dont know where you are located but if there is still an "old school" parts store around, see if they possible have an old Monroe catalog and see if you can find some part numbers and then search e-bay etc.
Old Jun 6, 2025 | 04:30 PM
JednTori88's Avatar
Jed,
The air lines are good, I jacked up the car and noticed the air shock rubber body has holes in it. I was gonna experiment with inner tube and contact cement.
Olds Dad
Dec 3, 2024 05:09 PM
oldsrocket88
Jan 26, 2022 02:12 PM
SpiderLovesBeer
Suspension & Handling
Feb 27, 2021 09:06 AM
88ToroSteven
Dec 25, 2011 01:37 PM
Pghstarsky
Jan 18, 2008 04:21 AM
