A few days ago I noticed a leak on the car. I poured some water inside the radiator and noticed it was leaking out of the buttom side on the driver side. I noticed the screw was loose and wouldn't tighten when twisting it. The question I have is when this happens do I need to buy a new radiator or should that piece just
screw back in? Here is a picture I took. Also, I have the diesel engine.
Reason: Please delete the third picture
I think the female part of that pet-**** is molded into the (left) end-tank of the radiator, so there's no replacing of the complete pet-****. If it's a matter of damaged threads, the male screw-in piece could be replaced. But if the end-tank female threads are damaged, I don't think there's any easy way to repair.
One of them in the picture looks like mines. I forgot to post a picture of mines. Here is a picture. The one that looks like mines have a piece and the middle where you see threads on mines. I'm not sure if that's the reason mines is leaking? All advance autoparts closed in my area about 4-6 months ago.
Reason: Correction
Ughh, I hope I never see the day when these type of stores cease to exist. As the do it yourself type car is being phased out ...
Mail order via internet if you can. I've done it with Autozone and it works very well ! In my case they protected small items like this in sturdy shipping boxes. And allow you to fully track the delivery. Yes I have one close to me but if its in another location sometimes not in the mood to drive.
Unfortunately I do not see one like yours in Autozone. But then I asked google for "1981 oldsmobile toronado diesel oem drain **** AC Delco" and this came up. https://parts.gmparts.com/product/ac...H4xYzIatePI2TD
However when I went to confirm fitment the listing only goes back to 1982... of course
Based on recent 2 pictures, I guess I was wrong about petcock partially being part of the radiator tank. Apparently, it is a separate part that can be replaced.
I would like to thank everyone for their input. I took the radiator to a local radiator shop. Luckily, they had the exact same one. Napa, Autozone, etc none carried the correct drain plug. Instead of paying $100's for a new radiator it only cost me $10. 😆
Reason: Adding picture
