View Full Version : Toronado
- FREE 68 Toronado parts
- Replacing 77 Toronado rear Bumper Fillers
- Pertronix ign
- 67 Toronado CV Boots Query
- Test drove a 76 Toronado, need some questions answered
- 1966 Toro Tele Tilt Acutator vs Edlo Actuator
- Oldsmobile Toronado GT 1970 - Fuel Tank Sending Unit
- Help with whitewall tires
- Shorty Toro
- 1978 Toronado Radiator
- 1984 Oldsmobile Dash Panel Removal
- 66?Toro runs shaky when warmed up
- 66 Toro vac diagram
- Air Shocks
- 66 Toro removing glove box liner
- Help needed: 2nd gen Toronado (1971) - weak points ?
- 66 Toro removing blower resistor
- 1984 Toro vaccum diagram
- 66 Toro vacuum tank question
- 66 Toro plastic vacuum lines
- Vacuum reservoir
- 1969 Toronado bonnet/front hood seal
- no spark , Alaska winter
- 66 Toro muffler
- Does '70 Toronado pwr trnk motor fit from other GM models?
- 1971 toronado drum brakes
- How to remove 1967 Toro front wheel bearings?
- 66 Torondao EV conversion
- Great site for early toronado info
- Toronado spindles
- sideways headlamps?
- '67 Starting trouble
- ‘66 Rear License Plate Lights Question?
- 66 Toro strange electrical issue
- 1967 Oldsmobile Toronado
- 70 w34 junkyard sighting
- Air Conditioner Muffler
- 1985 OLDS TORONADO 89,0000 miles
- Toronado 4bbl intake and quadrajet available in Indiana
- Toronado 66 Quadrajet
- 67 Toro torsion Bar removal Tool
- Anyone in central MA?
- 1969 Toronado Assembly Manual
- Special thank you
- 1967 Toronado Assembly Manual
- 1970 Toronado Assembly Manual
- 1966 Toronado Assembly Manual
- 1970 '9687' Toronado
- Speedometer Correction
- 66 Toro gas pedal question
- 1968 Toronado Rim Blow Wheel (Upgrade)
- 68 toronado disc brake rotors
- Brake warning light is on - 1977 Toronado
- Whistling sound from brake pedal
- Converting 66 to dual master
- Noob here- Need help with VIN for getting title
- Little custom fun with a '66-'67 air cleaner
- 1988 Toronado Trofeo - Help
- 67 Toronado correct drum brake shoes
- Painting dash near bottom of windshiEld
- Which Lubricant for 1967 Toro Differential?
- 1969 Toronado Tire Pressure decal
- Trunk weatherstrip issue on 66
- Edelbrock carb on a 66?
- 1978 Toronado XS and 1972 Toronado - Choices
- The '78 gains a stablemate
- AC vacuum diverter valve
- q jet fuel filter question
- 66 Toro screw on master cylinder cap
- 1987 Toronado
- 1966 Toronado ad sheet (not mine) CL
- 79 Toro in dash clock
- 1968 Toronado Hideaways Headlamps
- Manual antenna replacement
- 6 way driver side power seat motor in the case
- 1980 Olds Toronado questions
- Removing inside window trim
- '66-'67 Toronado air cleaner dimensions
- 66 Toro under dash bulbs
- Exterior door handles
- Power Steering Cooler on a "66 Toronado?
- Fusible link '66 toronado
- 66 trim rings
- Comfortron help
- Comfortron hard plastic vacuum line help
- Help on fan clearance on my Toronado 1967
- 66 Toro steering column
- 66 Toro aiming headlights
- Final drive problem 79 Toronado
- 66 Toro dash turn signal bulb
- 66 Toro pass headlight issue help!
- 66 Toro gas pedal mounting
- Back In The Olds Game!
- Critters on the Engine
- Back to the Body Shop
- Fresh Load of '66 Toronadoes for Parts
- Toronado Owners Manuals and Oldsmobile Accessories Brochures
- 1966 Front Brakes
- 25 footer...
- 66 toro radiator top plate
- 66 Toronado Bracket ID Help Please
- Nice set of 4 67-8-9 trim rings value
- Belt Line Seals - 77/78 Toronado
- 1972 Toronado
- Power Door Locks - 77 Toronado
- Correct Toronado hubcaps
- Passenger Side Mirror - 77 Toronado
- Door Striker Bolts - 77 Toronado
- 67 actuators
- Need Help with 84 toronado engine electrics
- Correct 1966 toronado air cleaner color . Help.
- 66 Toro window motors
- Power steering pump pulley
- 79-85 Toro Coolant Recovery Tank
- 66 Toronado Crankcase Venting
- Right rear side marker lens repair
- 1966 Toronado Code 054 Interior Vinyl Paint Question
- kick down cable
- '70 Toronado- rear side marker lens
- 1970- rear chassis mounts?
- New front motor mounts
- Toronado owners, what do you use for a console?
- Restored 79 Toro
- 1990 Toronado questions
- 1979 Toronado Brougham (Red)
- Looking for Left Door Switch Bezel 82-85 w/ Memory Option AG3
- Repair of fuel gauge ( not showing correct amount )
- Where to find a windshield?
- Maybe a Toronado owner
- Hagerty: had to crawl thru a Toronado to get to a Corvette.
- Pitman arm
- how do I test Vacuum Headlight Controller??
- Vacuum line hose size
- 1966 Quadrajet Number ?
- Fender or Quarter Panel Extenders
- 67 Toro
- 1966 going to the scrap yard
- NOS 1971-1978 Toronadp pass side rocker panel
- Here We Go Again - Engine Quitting 77 Toronado
- Has anyone replaced the weatherstripping on a 79-85 ?
- Interesting find for 77/78 Toronado owners
- 1968 Toronado Assembly Manual
- Toronado parts
- 1978 Toronado provenance
- Weather Stripping for 77 Toronado
- Restoring Factory Radio in Toronado
- 67 toro
- 67 Toronado - Oldsmobile - Protect-o-plate
- quick question about wheels
- 67 toro hood release doesn’t work - how can I get the hood open?
- 77 Toronado Exhaust Tips
- 1967 Toronado Tilt/Telescopic Diagram
- 77 Toronado Exterior Pinstriping
- How to revitalize the interior of 77 Toronado
- Need help with stuck 67 toro engine
- 1981 Toro Blower Motor Replacement
- I found my dream toronado
- Toronado transmission and engines
- Engine Quitting on 77 Toronado
- 77 Toronado Back From Paint Shop
- 1988 Oldsmobile Toronado Parts?
- 1966 GM Engineering Journal - 1st & 2nd Qtr
- 66 Toronado What color ?
- 1983 Toronado Transaxle
- bumper fillers on 1981 - 1985 toro's
- When do you know its time?
- 66 Toro Coupe or Deluxe
- 70s 80s 90s interior dome light
- 77 Toronado A/C Question
- 77 Toronado Body Side Moulding
- 1968 color
- Steering Knuckle casting#
- 1966 toro carb
- 1966 Toronado Engine Removal
- 1978 Toronado XS - from 1993
- 1969 Toronado
- cruise control and heat/AC system vacuum sources
- speedometer cable lubrication
- 69 toronado
- Anyone convert a '66 to manual?
- 15 Inch White Wall Studded Snow Tires
- To Chrome or Not To Chrome - That is the question!
- 1968 oldsmobile toronado gas tank info
- 77 Toronado Battery Tray Size
- 77 Toronado Steering Wheel
- From the photo archives, 1987
- 1978 Toronado XS -- first one built that year?
- Toronado Transmission
- Fuel line from Pump to Carb
- Toro for towing
- 1966 Toro headlight linkage
- A Pillar rust in a 1st Gen Toro
- 1968 Toronado Base vs Custom
- 67 Toro Differential Cover Gasket?
- 1978 Toronado XS - back from the paint shop
- '69 Toronado....Air conditioning question?
- 71 toronado starter location
- '69 Toronado...extremely warm front wheel?
- 1977 Toronado - worth a purchase and investment?
- Comfortron
- '78 Toronado, engine will start fine, but won't stay running
- '66 Toronado oil pan, new?
- question about radiator - 1978 Toronado
- Summer Cruiser - 1970 Toronado?
- what's the deal with the fuel pumps?
- '78 Toronado - dealer invoice
- '78 Toro - why do I cut the end off the link pin?
- what is this part? '78 Toronado
- Tornado wheels
- 67 patch panels?
- Coil-over Shock for '66 Toro
- How to change the heater core
- Save me from having buyers remorse, 68 Toronado
- Toronado Car Hauler
- 1966 NOS chrome exhaust tips
- What is this thing on a 67 Toro?
- 1966 olds Toronado disc brakes
- 66 Olds Shop Manual
- 66' Toronado Headlight Baffles Position
- WTB- 66-69 Toro floor pan section
- swapping Hinges '67 Toro doors
- Toronado styling concepts on ebay
- Headlight Switch to work w/actuators-66 Toro
- 66 Toronado LED Modification Question
- For Trofeo People Kid's New Car
- WTB- One 67 Toronado chrome disc brake wheel
- questions on 307 & 350
- 1985 toro shifting issue
- 1st gen doors
- Misc. '66 Toronado questions
- Comfortron years
- Comfortron parts
- Toro finally on the Road!
- Ming Jade 46
- Vacuum diagram needed
- 1967 Toronado chrome wheels cost?
- Toronado Headlight Action ???
- Cost of a Front Wheel Bearing
- Who makes Rear Exhaust Hangers for 66 Toro
- Another one followed me home, 1969 Toronado
- Toro Interior Before and After
- Fluid capacity for Turbo 425
- ignition bezel tool
- 2nd Gen Roof Rail Weatherstripping Question
- In Need of Toronado Exhaust Flanges
- Toro remanned part
- 1967 Toronado
- Ground Straps
- Rear Leaf Spring Bushing upper 1970 Toro
