questions on 307 & 350
Old October 18th, 2016, 05:35 AM
dal442's Avatar
presently on search for an 85' toronado caliente-- my understanding is that for 1984 -- 1985 there were a few optional powerplants...the 307 5.litre ---- 350--
5.7 litre -and the diesel. from what i have read it seems the 5.7 was done away with for 1985 ? is that correct ? because i would like to find one with the 5.7 gas engine if it was available...... or.... if you are a toro owner of a 84 or 85 model with the 307, i'd like some feedback as to performance and issues that you have had with your 307 motor....
also it seems some of you have had issues with the transmissions of these two particular years....again my understanding is that there were two options available....3sp auto and 4sp auto ? any opinions as to which you would prefer or any particular problems that you have encountered.
dal442
dal442 is offline
Old October 18th, 2016, 06:37 AM
dal442
The last Oldsmobile 350 gas engine was made in the 1980 model year. The 307 was the only Olds gasoline engine built in the 1985 model year. All small block Olds motors (260, 307, 330, 350, 403) are externally identical and are bolt-in swaps for each other.
joe_padavano is offline
falconsfan
May 14th, 2015 05:47 AM
455man
April 23rd, 2013 10:39 AM
carbonf00tprint
November 4th, 2012 07:53 AM
kern84
Hurst/Olds
August 23rd, 2011 06:25 PM
Quick Reply: questions on 307 & 350
