Toro for towing
Toro for towing
Hi everyone.
I've been thinking I'd like to have a mid 70s Toronado to pull my 31ft Airstream. My first thought was, this is the biggest car I can think of it will do great. But in typical fashion, I started overthinking and now wonder if the front wheel drive will somehow adversely effect towing capabilities.
So, does anyone tow a big camper with a Toronado, and does it do well or poorly? And if it does well, would I be even better with an Eldorado and 45 more cubic inches?
Thanks everyone. Have a good evening.
I've never towed with the '76 or '77 Toronados I've driven, so I can't speak to the road manners.
I believe all of the '77s only came with 2.73 final drives. It's not very swift from a dead stop all by itself, so you're not going to win any drag races adding a trailer.
'76 was the last year for the 455, so I would look there or earlier myself. If you do go through with it, that will be an awesome sight to behold!
Good Luck!
Good Luck!
I think a 70s Toro would do fine towing a trailer. Just put some leveling shocks on the back and make sure you have a good hitch. It's not like you want to tow a 5th wheel trailer or something.
FWIW, I wouldn't suggest going to an Eldorado, they aren't Oldsmobiles.
A good friend of mine was working at the GM Desert Proving Grounds in the late 70s when they were shooting those commercials. He likes to point out that when the cars came back in after filming, the drivers had to climb out the windows because the body was so tweaked that the doors wouldn't open.
funny you should say that years ago we were cruising down the divided 4 lane highway and came up on a camper doing maybe 50 or so.so we go to pass the guy and it was a 5th wheel trailer being pulled by an eldorado.guy built a mount setup that went thru the top of the 1/4s i assume they went to the frame.was kinda cool
A truck has a full chassis and a better suspension. Why would you pull a heavy trailer with a passenger car???? Rear suspension isn't designed for it, Car will wag it's tail going down the road. To me it's not worth the hassle when their are better way's of doing something.
I went to the Olds 100th anniversary in '97 and two people I know trailered their cars there. First guy used a Dodge 2500 series pick up and didn't even feel the car and trailer back there. The other guy used a Ford Bronco ( short wheelbase and soft suspension) and the ride from Long Island to Lansing was terrible.
I would even say dangerous.
A 31 foot trailer is heavy and a wind catcher, As much as I like an Olds Toronado I wouldn't feel comfortable using it for that.
Also a prius is a terd
As a truck driver for the last 25 years it's better to have a tow vehicle with the right suspension and wheelbase. To pull a small boat or camping trailer with a Toro is one thing, 31ft is ridiculous.
Thanks guys for all the input. Ancient Iron I agree with you that a pickup(mine anyway) is a better tow vehicle. I can't help but think you're thinking I'm talking about the 80s Toronado. I'm actually talking about a 71-76 Toro. And Olds64 is right, I'm going for a certain look, vintage car and vintage [look] trailer.
I have an 02 Silverado 2500HD which is more than enough. My Airstream Sovereign weighs 7000 pounds. The Toro would be no slouch, either, and better than 90% of the tow vehicles I see around. But, according to Joe's chart, the Airstream is too heavy for the Toronado. Wonder if it's a capability of the power train or the platform in general.
Kenny do you know of a green 71 88 convertible? I'd drive one of those without a trailer.
Thanks again everyone. This has been very enlightening and enjoyable.
Also remember when your going down the road you have to think safety. Your life and your families or anyone else's for that matter are not worth risking just to look cool.
When things go bad they go bad FAST.
That's what makes Eric's film clip so poignant. In that movie they really were towing that large trailer up the mountains, and the Mercury didn't have the ***** to do it, so they substituted a Lincoln with the bigger motor in some of the scenes.
I do a lot of towing with my pickup which is why I asked about this particular car in the first place; no experience with it and wanting to learn before getting in over my head.
Interestingly, I would consider towing a trailer with my 71 98 over towing with my 86 f250. While my pickup is a 3/4 ton truck, the diesel is naturally aspirated. It's sort of a dog on the highway.
Oldsguy has a dual axle RV he tows behind his 2017 f250. I may borrow it someday and tow it with my truck; however, I will be staying in the right lane the entire time thinking it would be easier with my Oldsmobile.
Now is 7000lbs a dry weight??? If so add water and all the supplies you need to live in it plus all the family in the car, and before you know it you have exceeded a safe weight limit. Add some steep grades and hot summer weather in Georgia and you just set your self up for disaster.
A small trailer would be cool, But when he said 31' even if it's an airstream the steel frame and axles are still steel and would stress that car past it's limits.
A '71 98 has the power but the rear springs are the weak point.
#31
#32
I might be a little off here. I went to look at the body tag on the trailer and it says GVWR is 6800. A quick search shows empty weight is 5400. That still outweighs the Toro spec by 400. I wish more people had a forum like this to check their rigs. I see 1/2 ton pickups and the full size Japanese pickups(which aren't as full size as our full size) towing trailers at least this big.
Thanks again all. I've learned a lot.
#33
My old man owns a 67 Airstream that we used for hunting. We have moved it a couple times with a 95 Tahoe 2 door, in central FL, being very careful. Airstreams tow nicely, but they still have a lot of mass.
#34
Towing with a Toronado... Hell Yes!
My Parents pulled an 18' Aristocrat Land Commander (Deluxe with Shower & Toilet) back & forth across the US of A many times... including the Continental Divide.. Deserts (they lived in CA, CO & NV... Visited Grandchildren in Northern CA, CO and MO).. in rain, snow & heat... with a 1985 Toronado with the 307! The Aristocrat Land Commander is NOT a Light Trailer... Empty Weight 2250 lbs... also had 2-30 Potable Gallon Water Tanks and a 30 Gallon Black/Grey-Water Tank. Upgraded with a Pair of Deep Cycle Batteries, Twin 30 Gallon Propane Tanks and Roof Mounted A/C. Probably closer 4000 lbs Wet with all of their 'stuff' in it... My Parents did NOT travel 'light'!
The Toronado was equipped with an Equalizer Hitch, Anti-Sway & Trailer Brakes and I installed an aftermarket Transmission Cooler to supplement the stock cooler. Never an issue.
Still running original Engine & Transmission. Still runs nice (now that I have sorted out an emissions issue).
Just sayin'...
Just sayin'...
