1966 olds Toronado disc brakes
Old Jan 4, 2017 | 08:10 AM
lostinspacetv's Avatar
I have a 1966 Toronado, want to change front drum brakes to disc. What year of Toronado's can I choose from. From what I've read, I need upper control arm, spindle, caliper and caliper mounting hardware. Also wheels, brake booster and master cylinder, with lines.
Old Jan 4, 2017 | 10:54 AM
rocketraider's Avatar
Oldsdruid
69-73 Toronado and Eldorado are pretty much a bolt-in. 74-78 will work using outer tierod ends and ball joints for those years. You will need to get the proportioning valve from the disc brake donor car as drum cars do not have it. That or get a Wilwood adjustable one.
Old Jun 5, 2017 | 07:18 AM
Mike, you PMed me and mentioned that you found two different ball joints when converting your Toronado to front disc. Unfortunately, I don't know the specifics of this conversion. I do know that upper ball joints provided by manufacturers for many Oldsmobile applications are either a wrong part number; or at the very least, a cheap Chinesium part.
Not to complicate things; however, I know the B/C bodies during the 60s had two different tie rod ends (Sagniaw and Tecumseh). They had a different taper and different measurements and aren't interchangeable. I'm not sure if this applies to the difficulty you're having with your Toro. Let us know what's up.
Old Jun 5, 2017 | 02:41 PM
I'm not a Toro expert, but the factory parts book shows one set of upper and lower ball joint part numbers for the 66-70 Toros and a different set of part numbers for the 71-75 Toros.
Um... That's Saginaw and Thompson.
FYI that "Thompson" was the "T" in TRW (Ramo and Wooldridge were the two satellite guys, Thompson was the car guy).
Old Jun 6, 2017 | 05:26 AM
I thought it was Saginaw and Tecumseh after the cities near Detroit, MI.
Old Sep 11, 2017 | 03:17 PM
66toro_mn's Avatar
Here is a page with a lot of information on this subject - I am planning this project myself too
http://www.breznick.com/toronado/brakes/index.htm
Old Sep 20, 2017 | 12:12 PM
cougla's Avatar
Kanter AUTO PARTS sell kits for this. Look in their Catalogue. I just noticed the other night as I was looking myself for a kit. About $1,200 bucks
Old Sep 20, 2017 | 12:51 PM
Or, you can get used original disc brake parts for about $120.
CutLS442
Brakes/Hydraulic Systems
Nov 23, 2016 12:50 PM
2blu442
May 22, 2016 10:00 AM
Soylentgreen
Jul 17, 2014 01:54 PM
gs63
Mar 19, 2013 09:24 AM
willz64
Apr 29, 2010 11:48 PM
