disc brakes for 63 olds 98
Old Jan 27, 2013 | 09:50 AM
gs63's Avatar
Question disc brakes for 63 olds 98
l need info on installing disc on my old ,98 .what spindles will intrerchange with it?
Old Jan 27, 2013 | 10:37 AM
Tedd Thompson's Avatar
You will probably get a better response on your post if you drop on down to the forum related to your post. I would try the tire and brake forum or the 98 forum, someone will give you a hollar, this subject has come up before...Tedd
Old Jan 27, 2013 | 11:42 AM
rocketraider's Avatar
Oldsdruid
None. You're going to have to get Scarebird or DiscBrakeMike (Mike Pemberton) to modify what's there. Good thing is both of them have researched easily available parts to make this conversion relatively pain-free.
Old Mar 18, 2013 | 09:07 PM
rr480's Avatar
kanters/auto parts has a complete kit, power brake booster dual master cylinder proportioning valve 2 rotors 2 calipers mounting brackets. wheel bearings for $1,099.00 and is suppose to be bolt on
Old Mar 19, 2013 | 09:24 AM
D. Yaros's Avatar
And more probable than not, requires that you mount your new 15" tires & wheels on the new setup.
72allblackcoupe
Apr 6, 2014 07:20 PM
steve walker
Feb 6, 2013 07:25 PM
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
russell-t
Apr 30, 2011 05:56 AM
willz64
Apr 29, 2010 11:48 PM
