disc brakes for 63 olds 98
You will probably get a better response on your post if you drop on down to the forum related to your post. I would try the tire and brake forum or the 98 forum, someone will give you a hollar, this subject has come up before...Tedd
None. You're going to have to get Scarebird or DiscBrakeMike (Mike Pemberton) to modify what's there. Good thing is both of them have researched easily available parts to make this conversion relatively pain-free.
And more probable than not, requires that you mount your new 15" tires & wheels on the new setup.
