What is this thing on a 67 Toro?
Old Jan 11, 2017 | 10:13 AM
SL1's Avatar
SL1
What is it?
​​​​​​​That canister- looking thing on the driver's fenderwell. All that I know is that it's a California car with cruise control. Please see attached picture. Thanks
Old Jan 11, 2017 | 03:49 PM
2blu442's Avatar
I've seen these on 1966's but not 67's. Its part of an early emissions control system required on California sold cars. You should also have a smog pump located below the AC compressor on the passenger side of the engine. There will also be additional vacuum lines/fittings on the engine, and steel lines attached to the heads one fitting going into each cylinder. Since I live right on the Oregon California border I've come across several cars with this setup. John
Old Jan 11, 2017 | 05:01 PM
SL1's Avatar
SL1
John- Thanks for the explanation. I wasn't familiar with the California- only emmisions equipment.
Steve
Old Jan 11, 2017 | 05:17 PM
2blu442's Avatar
Hi Steve
My memory was off just a little bit. I looked at photos on my photbucket site and have picture of both 1966 and 1967 cars with this system on it. John
Old Jan 11, 2017 | 05:23 PM
SL1's Avatar
SL1
Thanks John. I was thinking that it looks like it could be a charcoal canister? Maybe it had a replaceable filter under that ribbed top?
Old Jan 11, 2017 | 05:40 PM
SL1's Avatar
SL1
John- From your explanation above I found a picture of it from Fig. 6EB-11 from my 67 service manual. It's called a "Filter and Silencer Assy". A hose connects to the air pump. I was wrong above thinking it was a charcoal cannister. Thanks again for your help. Mystery solved! Steve
Old Jan 11, 2017 | 05:50 PM
So, basically, an air cleaner for the AIR pump.
If I'm not mistaken, in later years it was replaced by a 1" chunk of felt in a receptacle in the back of the AIR pump.
Old Jan 12, 2017 | 07:11 AM
Originally Posted by mdchanic
so, basically, an air cleaner for the air pump.
^^^this.
American Lead
Apr 20, 2009 12:47 PM
jeffs 89 cutlass salon
Oct 7, 2007 05:59 PM
American Lead
Sep 18, 2007 05:18 PM
American Lead
Apr 3, 2007 03:04 AM
Want-A-Vert
Jan 15, 2007 12:02 PM
