Final drive problem
Old February 17th, 2018, 03:33 PM
bw1339's Avatar
Final drive problem
Hello,
I'm putting a '75 final drive in my '66. After resealing it, I noticed that the driver's side output flange has about 0.040" of side to side play, and about the same in in-out play. I can see the driver's side diff gear moving with it.
I have a couple of '66 final drives and that flange is rock solid in both of them. But these have planetary differentials, vs a conventional one in mine. Is this normal? Unfortunately I didn't check if the play was there before I did anything to it, but all I did was pull the flange and replace the seal.
Thanks.
bw1339 is offline
jharsh
December 2nd, 2016 08:12 AM
montvaleplace
Drivetrain/Differentials
February 21st, 2016 05:26 PM
Roger60
August 14th, 2015 05:58 AM
Otto Skorzeny
March 13th, 2014 07:16 PM
May 18th, 2010 04:35 PM
Quick Reply: Final drive problem
