Fluid capacity for Turbo 425
Old Apr 15, 2016 | 10:34 PM
z11375ss's Avatar
Senior Moment Member
I filled the converter before install. Then tonight fired the motor. Added 8 quarts. Not even on the stick! How much more? Opinions?
Old Apr 16, 2016 | 09:55 AM
Trailrunner's Avatar
Trailrunner
The capacity with a complete overhaul is listed as 10.5 quarts. To remove just the pan is listed as 5.0 quarts.
1. How much did you put in the converter?
2. Did you move the gear selector through all of the gears with the motor running before checking the fluid level?
Ross
Old Apr 16, 2016 | 09:48 PM
z11375ss's Avatar
Well, I ended up putting in about 12 quarts. The trans works now. Hooray. Almost took it for a ride to get gas but the headlights wouldn't come up. Vacuum issue for sure. I'll get it sorted out tomorrow I hope. Thanks for your input.
oldjunk
Jun 17, 2009 11:55 AM
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
ziff396
Apr 2, 2009 08:01 AM
Pete77
Drivetrain/Differentials
Jul 22, 2006 12:12 AM
Pete77
May 15, 2006 05:37 PM
