66 Toro under dash bulbs
Old Dec 30, 2020 | 05:29 PM
sgolds's Avatar
What is the correct bulb for the under dash courtesy lights on a 66 Toronado? I have 2 #90 bulbs but I had a hard time screwing them in. Not sure if they're correct or not
Also, should the bulb have 1 or 2 contacts on the bottom?
Old Dec 30, 2020 | 07:08 PM
OLDSter Ralph's Avatar
Will this help you ?
Old Dec 30, 2020 | 07:16 PM
sgolds's Avatar
Thanks for that, very helpful
I wonder what it means by ignition light and front seat back bulb?
Old Dec 30, 2020 | 07:39 PM
I think you mean ignition switch light ? There must be a bulb some place close. Front seat back is probably in the back of the front seat, probably at the bottom to light the floor. I can't go take a look til next week when it gets warmer outside. I have scanned the owners manual, if you would like a copy of that.
Old Dec 31, 2020 | 05:24 PM
sgolds's Avatar
Didn't know Toronado had an ignition switch light, you learn something new every day 😎
Old Dec 31, 2020 | 07:11 PM
rocketraider's Avatar
Oldsdruid
Most fullsize Oldsmobiles had an ignition switch lamp thru 1968. Don't think I've ever seen one on a GM locking column through strangely a lot of Chrysler products did, and they bought Saginaw steering columns from GM.
You'll also see a little green jewel light above each dash ashtray. They disappeared for a few years in early 70s but reappeared when the big cars downsized in 77. One of those little touches that made an Oldsmobile an Oldsmobile.
Old Jan 2, 2021 | 01:28 PM
sgolds's Avatar
Oldster, that would be great if you could check that, I wonder if there actually is a light under the back of the front seats
Andy
Dec 16, 2020 10:28 AM
simrek1
Feb 22, 2017 10:57 AM
mats
Jun 4, 2015 06:07 AM
BigWelder036
Jan 2, 2014 05:42 PM
tornardoman
Feb 28, 2009 01:18 PM
