66 Toro under dash bulbs
What is the correct bulb for the under dash courtesy lights on a 66 Toronado? I have 2 #90 bulbs but I had a hard time screwing them in. Not sure if they're correct or not
Also, should the bulb have 1 or 2 contacts on the bottom?
Most fullsize Oldsmobiles had an ignition switch lamp thru 1968. Don't think I've ever seen one on a GM locking column through strangely a lot of Chrysler products did, and they bought Saginaw steering columns from GM.
You'll also see a little green jewel light above each dash ashtray. They disappeared for a few years in early 70s but reappeared when the big cars downsized in 77. One of those little touches that made an Oldsmobile an Oldsmobile.
