PDA
View Full Version : Toronado
Pages : 1 2 3 [4] 5
  1. need a WORKING! Wiper Motor
  2. need a WORKING! Wiper Motor
  3. 425ci synthetic oil smoking?? Lumpy on start up...
  4. Need a 67 toronado body
  5. 1966 toro master cylinder upgrade..
  6. 66 toronado $1300
  7. Toro drivetrain-drive it home in a Yugo Detroit C/L
  8. 69 Toronado parts needed
  9. 1969 Toronado & 1967 Delta 88 in So. Cal. Junk Yard
  10. power window option.
  11. 66 Toronado Coolant Recovery Tank
  12. 68 toro fuel tank
  13. 68 Toro - weakness of old age
  14. Toro's
  15. 70 Toro grille question
  16. interchangeable parts info?
  17. help data plate
  18. '70 Toro parts; rusty body
  19. priority list
  20. Junkyard Toronado Awaiting Rescue
  21. HELP! Decal locations on 66 Toronado
  22. 66 Tornado Muffler
  23. eliminating points ignition?
  24. new owner 68 deluxe
  25. 1968 Toronado - Blow By Issues
  26. Possible '69 part out.
  27. 1966 Toronado Floor Mats, headlight cannisters
  28. Replacement Value 1966 Toronado
  29. 1969 parts needed
  30. 69 olds toronado
  31. Steering column interchagne
  32. 70 Toro rocker molding clips
  33. 1966 Toronado Exhaust
  34. 69 Toro Output Shaft assembly needed
  35. 70 toronado wheel well moulding
  36. 70 toro gt exhaust tips
  37. Vacuum line routing on 307 y 5a
  38. 66 toro headlights
  39. Wheel bearings and Torsion bars
  40. TOA site offline?
  41. 90 Trofeo
  42. Edelbrock carb on 70 Toro
  43. 66 Toro steering wheel in a 67???
  44. 67 Toro steering wheel in a 67???
  45. Torsion bar question
  46. 1970 gt
  47. Torsion bar adjustment
  48. 72 toro seats on ebay . . . not mine
  49. FS 1966 toronado clocks
  50. 1966 Toronado trunk photos needed
  51. Fitting a 72 cutlass convertible
  52. panel behind rear seat?
  53. 67 Toro front door handles
  54. Toro Dual Snorkel Air Breathers
  55. Help, 70 Toronado not starting (long)
  56. series 1 exhaust manifolds
  57. 1969 toronado disc brake setup
  58. 1966 Toronado Owners Manual, Protection Plan, Window Sticker,Owners Plate on Ebay ---
  59. Anybody have a 79-85 Toronado???
  60. Dipstick won't go back in, 70 Toro
  61. Suggest an intake manifold for 68 Toro?
  62. 1966 - 1967 Toronado Headlamp Canister Interchange
  63. Buy a 1989 Toronado?
  64. Is this 66 worth $1,200?
  65. 1991 Trofeo "Electrical System Problem" in VIC display.
  66. Twin Engine Toronados?
  67. 70 Toro - steering column interchange
  68. Hub Caps 68 Toronado
  69. Possible repro gas tank for 66-70's !
  70. 70 Toro - trim rings
  71. 1969 Chestnut Bronze - any pic's?
  72. Eighties Toro question
  73. 1970 toro oxford gray color ?
  74. Alt. light 70 Toro
  75. 66 toro turn signal switch broke! Need Pics!
  76. Reproduction parts for Toro
  77. 68 455 Engine specs
  78. 66 toro dieseling
  79. Rocker panel mounting clips
  80. Clip pics
  81. Bolts for horizontal shocks / Size / Toro 1970
  82. Putting on the trim...
  83. Reverse light lenses
  84. 1969 Toronado in NW Washington state
  85. '67 Toronado Temp Gauge Retro into a '68
  86. '66 - '67 Bumper interchange?
  87. 66 Toro headrests and tilt tele column
  88. 1973 Toronado filler needed
  89. '70 Toronado GT
  90. Replacement floor pan?
  91. '68 Toro Front Bumper Emblem
  92. Steering wheel
  93. Speedo light out - 85 Toro
  94. Help Me
  95. Speaker thingy
  96. 68 Toronado parts for sale
  97. 69 barn find
  98. My first Toronado
  99. 67 Toronado Parts for sale cheap
  100. Carb Question
  101. 'Considering this '81 Toro
  102. Body mount bushings
  103. moon roof gasket/seal for 1987
  104. 66 toro headlight actuators
  105. Pic Dump: Bringing a '68 back to life
  106. '66 Toro rear brake hose needed
  107. '66 TORO - DIFFERENCE BETWEEN "94" and "96" MODEL SERIES
  108. WANTED!! 66 or 67 toronado shell in good shape
  109. will a SBO work on a toronado transmission?
  110. In search for a 68 Toro gas tank
  111. 66 Toronado Upholstery
  112. Strange looking brackets on the floorboard?
  113. Pics needed ...Toronado Brake Lining etc.
  114. How rare is a 1966 Toro A/C delete?
  115. i have 74 toro parts
  116. 1970 Toronado GT camper
  117. Torsion Bar keys
  118. 1970 toro part - alternative relay
  119. 1970 Toronado - questions
  120. Toronado hubcap Interchange
  121. 68 Tire info
  122. The Fast Toro Project
  123. 66 Gas Gauge Question
  124. replacement valves
  125. 66-69 Toronado MPG
  126. Help- Photo Help Needed - 68 Toronado
  127. So let us make a list of hard to find or rare parts for toronados!!
  128. radio resistor? 70 toro
  129. Name that wire/connector?
  130. TH425 wont shift into 3rd
  131. 66 toro fasteners and rubbers
  132. 69 toro power antenna and heated back glass RARE??
  133. Name that relay
  134. 66 toro tilt/tele steering column
  135. Lower Ball Joint Removal
  136. Toro 68-70 left exhaust manifold
  137. 66 toronado mech. in Maryland
  138. question about keys ('69)
  139. removing seats in a '69
  140. Value of a nice set of trim rings ?
  141. Radiator Replacement Article, '84 Toro
  142. Chrome 66 toro tailpanel
  143. Radiator replacement?
  144. Anyone know what this bracket is?
  145. Motor Trends Car Of the Year - '66 Toronado
  146. 67 barn find
  147. complete 66 tornado restoration need help!
  148. Are toro exhaust manifolds worth selling?
  149. 1st Gen Toro - Bouncing Speedometer
  150. Correct finish for trunk pan
  151. ok here's my hole!....
  152. Toronado resto-mod?
  153. whats this button on my shifter, 70 toro
  154. Toronado Parts in RI: Free (or for a 12-pack)
  155. who's put hei in pre 75 toro?
  156. new puzzle...vette master?
  157. Anyone got engine pics?
  158. 67 olds toronado
  159. dark blue engine paint...who's got it?
  160. Heater control System issue....
  161. Climatrol
  162. where can i get a posi unit for a toronado ?
  163. Has anyone heard of this car?
  164. Toro hubcap scam?
  165. GM Toro hoses
  166. 1970 Toro w/buckets and console
  167. 1985 toronado
  168. looking for parts -70 toro gt
  169. Nice Toro For Sale
  170. 67 Toro dash cluster and AM/FM radio
  171. New guy in Oklahoma. All help appreciated!
  172. mid 70s Toro / rocket emblem
  173. c'mon you guys!...1 friggen hubcap....
  174. th425 OM w/factory stall conv
  175. '68 TH-425 Diff. Vent ??
  176. Central Power Supply
  177. 70 center hub caps
  178. power seat back release
  179. rebuilt / restored 69 Toro carb 7029252
  180. What do you need off my 69 toronado?
  181. 66 toro vacuum headlamp canister retrofit?!?
  182. Toro 68 Interior
  183. Torsion Bars
  184. I have decided on a Toronado
  185. 67-68 Toro/Eldo Disk Rotors
  186. 66-67 Toro Molding Clips
  187. 1987 Toro control arm
  188. 87 Toro
  189. 5-69 Toro chrome disc brake wheels for sale
  190. Headers
  191. 85 Toronado Horn
  192. 66/68 Exhaust manifolds-interchangable?
  193. 71 toronado tranny
  194. Project High Toned Sonofabitch
  195. TORO For Sale
  196. toronado thingamajig
  197. Thoughts on the early Toronados
  198. AC Airflow Problem
  199. where to get reproduction parts
  200. pulling a tranny, 85 olds
  201. Engine Trouble(rough starts)
  202. ATTN: all 66 Toro Guys. 2 days left.
  203. rear bumper
  204. parting 1985 toronado caliente
  205. vacuum acuators 66 toro
  206. 69 Toro Engine Removal
  207. Glad to be here.
  208. XS Photo´s
  209. 1967 Toronado Headlight Installation
  210. New member - Need Toro help.
  211. Do I have cornering lamps?
  212. 68 Toronado
  213. Help finding someone parting out a '66 Toronado
  214. What do you think . . . value of a 77 toronado XS???
  215. Please Help....Good Deal???
  216. Greetings from the old world...
  217. I think I have a 1968 W34 distributor
  218. 67 Toro chrome wheels
  219. How many???
  220. WANTED 67 TORONADO FRONT HUB /BEARINGS
  221. 1968 Toronado for sale $4500
  222. 66 Toro front strato and rear seating & headliner
  223. 67 Toro with buckets and console
  224. 1967 Toronado Dashboard
  225. 67 Toro cruise control
  226. 66 - 67 Toro license plate light lenses
  227. Headlight switch
  228. Toronado AQC JETWAY 707
  229. Instrument Panel Power supply
  230. '68 Toro
  231. Hurst Toronado?
  232. Wanted '66 Toronado Fenders
  233. Transaxel positraction
  234. Oil sending unit
  235. Number of 66 and 67 Toronados with bucket seats and console
  236. Wanted: 67 Toro Climate Combusion Control Breather
  237. 66 toro valves
  238. Determining '85 Toronado's build date
  239. 1966 Toronado Fuel Tank Vent Configuration
  240. 1966 Toronado Fuel Tank Vent Configuration
  241. pulling this toro motor
  242. New 1974 Toronado
  243. 68 Toronado
  244. 66 425 toro crank
  245. 72 toro
  246. 1978 Toronado for Parts
  247. 1991 Trofeo Touring?
  248. 66 Horn Button Installation Problem
  249. Headlamps Will Not Open
  250. 66 Steering Column Disassembly
