th425 OM w/factory stall conv
Old Nov 6, 2009 | 12:33 PM
cadillackid661's Avatar
Hello,1970 Toronado GT,W-34.I need to find out,who sells a complete,quality and correct overhaul kit,for the trans.It is the orig. unmodified O M th425.And they do differ internally,so I need to find a knowledgable supplier so i get all the right parts the first time.It's my daily car so down time is killin me.Thanx for any help.
Old Nov 6, 2009 | 01:37 PM
rocketraider's Avatar
Oldsdruid
Unless you find some NOS stuff I expect about all any supplier will have is generic rebuild stuff. Even so the parts you'll use in a rebuild shouldn't affect shift points and calibrations that much. Just put the same number of clutches in each pack as came out of it, note where all the check ***** and springs came from, make sure everything is cleaned, and the valve body and governor ought to give you the same characteristics as before.
I think I have a 69 THM-425 parts requisition booklet. If I can find it, I'll be happy to copy and snailmail it. No scanner.
Edit: Turns out I don't have a 425 parts requisition, they're all for Jetaway and HydraMatic. I got it confused with 69 Toro A/C requisition booklet. Best I can do is a "Systematic Troubleshooting Guide 400-425" but it has no part numbers. Strictly a diagnostic.
Old Nov 6, 2009 | 05:00 PM
toro68's Avatar
Maybe try Dick Miller ( he rebuilt the OM tranny in my gold 1968 w-34, about 1994-1996,before i owned the Olds)
Email: dmracing1@aol.com
(662)233-2301,FaX (662) 233-2381
Old Nov 7, 2009 | 12:04 AM
my concern is more for the fact of having to wait for parts(fiber,steel or seal)I know theres diff #'s ofdiscs etc. UPS takes to long the first time when the market is a 2mi. walk.My vette and pu are apart also.DAMN that murphy anyway.
Old Nov 7, 2009 | 06:07 AM
kaz442's Avatar
Try Fasco, they are located in NJ and specialize in older transmission parts. 973-227-2487
JKaz
Old Nov 8, 2009 | 11:47 PM
hey thanx!
EightballZ
Feb 17, 2013 10:31 PM
Batmobile66
Jun 18, 2010 01:27 PM
cadillackid661
Nov 6, 2009 12:29 PM
papabear4208
May 27, 2007 12:07 PM
