71 toronado tranny
Old May 10, 2009 | 10:21 PM
MrClassic's Avatar
71 toronado tranny
Hello all I am looking for info on a 71 toronado transaxle removal, whats the trick?? crossmember can't be removed, its WELDED in. Thanks
Old May 10, 2009 | 10:40 PM
2blu442's Avatar
I've pulled them from 66-67 Toro's and once the engine was out it wasn't too bad. I removed the bolts that attached to the CV joints, removed the bolts that hold it to the rear crossmember..... and now I remember! It was a battle pulling it forward against the steering arm and getting the differential high enough yet pulling it forward and up at the same time. Yes it was quite a pain but with a hoist, floor jack and a 2X4 it came out. Have you located the transmission mounts on that rear crossmember? John
Old May 11, 2009 | 06:11 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO, hope you get your job done without too much trouble.
Old May 22, 2009 | 08:07 PM
Ed Cole's Avatar
It is likely to be easy for you...
I did one with a small jack. Got it back in alone.
Old May 22, 2009 | 08:27 PM
MN71W30's Avatar
I did a couple many years ago on a 66 and I pulled the motor and tranny out together. It has been 26 years and I can't remember the details.
Old May 22, 2009 | 09:23 PM
2blu442's Avatar
Hopefully you have it out by now. Can we get an update on how it's going?
QuinnKnight
Nov 7, 2019 05:19 PM
schaferak
Apr 22, 2013 06:37 AM
joelow83
Jul 13, 2006 03:19 PM
Tweety
Apr 28, 2005 06:23 AM
JP63
May 19, 2003 02:05 PM
