Dipstick won't go back in, 70 Toro
Old Oct 12, 2011 | 09:17 AM
sgtoro's Avatar
Help, I pulled the oil dipstick to check the oil on my 70 Toronado and now it goes about halfway down and bumps into something inside the tube when you try to put it back in. Anyone ever have this issue before?
Old Oct 12, 2011 | 09:31 AM
TripDeuces's Avatar
I thought my Toro had a flat spot on the tube where you had to rotate the dip stick to get past?
Old Oct 12, 2011 | 10:57 AM
1971Cutlass's Avatar
In Recovery Mode
Do you know if the dipstick is original?
Or is this the first problem you have had on it?
I might replace my dipstick on mine becouse it is really hard to put it back in. Hope it works out.
1971 Oldsmobile Cutlass Sepreme Sedan-183,000 Miles
2001 Toyota Sequoia-210,000 miles
2003 Chevy Suburban-153,000 miles
1999 Mazda Miata-131,000 miles
Old Oct 12, 2011 | 08:54 PM
sgtoro's Avatar
Yes, it is the original, also it worked OK until the other day, I tried rotating it but still does not work
stevengerard
Sep 10, 2014 03:17 PM
dantecl
Oct 27, 2013 02:50 PM
Jolly Green
Jan 16, 2013 05:07 PM
67w30
Apr 22, 2011 05:36 AM
jtriggy
Apr 28, 2010 07:10 AM
