Dipstick won't go in (1970)
Old Apr 27, 2010 | 02:20 PM
jtriggy's Avatar
Hi,
Stupid/frustrating question: The oil dipstick tube on my rebuit 350 is a little loose. I removed the dipstick to check the oil and it seems to be getting stuck a few inches from going in. Am I missing something? Soooo frustrating.
Thanks,
James
Old Apr 27, 2010 | 02:51 PM
svnt442's Avatar
I have a similar with my 455. I have to basically force it back into the tube. I have no clue what was done to the tube but it is a pita to check the oil.
Old Apr 27, 2010 | 02:57 PM
Bluevista's Avatar
Registered
Dipstick won't go in?
I hate when that happens.
Old Apr 27, 2010 | 03:03 PM
Shizzy's Avatar
I hate to ask, but did you try spinning the dipstick 90 or 180 degrees? Mine only goes in proper one way.
Old Apr 27, 2010 | 03:05 PM
rtpassini's Avatar
thats what she said.
Old Apr 27, 2010 | 03:27 PM
MJAKS462's Avatar
She told me you have to lube it sometimes for it to go in properly and it still might not go in all the way.
I have a new tube and dipstick on the way , any tips for installing it correctly.
I am being serious now.
Old Apr 27, 2010 | 05:46 PM
Blk71SX's Avatar
do you have a flat dipstick or a round one? the dipstick in my 455 is round but I've noticed the replacements I've seen are flat. the flat one have to be turned correctly to make the curve in the tube where the round ones will flex in any position
Old Apr 27, 2010 | 08:28 PM
stevengerard's Avatar
my dipstick is round and long and won't always go in all the way either.
Actually... on my 455 I have to spin it a bit sometimes as well
Old Apr 27, 2010 | 08:57 PM
442much's Avatar
OK, OK, I thought this was a Viagra question.......
Old Apr 27, 2010 | 09:57 PM
Jaybird's Avatar
Originally Posted by MJAKS462
you have to lube it sometimes.
Exactly... You have no oil in your engine!
Old Apr 28, 2010 | 05:22 AM
Lady72nRob71's Avatar
I am glad I am not the only one with this issue - the stick in my 72 is flat and is hard to get back in.
Is the 72 350 stick round? If so, I will need to get one.
Old Apr 28, 2010 | 07:10 AM
Blk71SX's Avatar
Originally Posted by jtriggy
Hi,
it's possible the tube has broken where it enters the block and has become misaligned.
when I got my Olds it had headers. apparently when the headers were installed the tube was treated rudely, becoming loose. eventually it broke off completely. the tube would come off with the dipstick when checking the oil. because of the proximity of the dipstick hole and the positive cable connection on the solenoid great care had to be taken when replacing the dipstick or the sparks would fly.
when I swapped the headers for the original manifolds the tube was replaced.
stevengerard
Sep 10, 2014 03:17 PM
dantecl
Oct 27, 2013 02:50 PM
Curts1970cutlass
Mar 11, 2013 12:46 PM
Jolly Green
Jan 16, 2013 05:07 PM
sgtoro
Oct 12, 2011 08:54 PM
