66 Toro plastic vacuum lines
Old Dec 23, 2021 | 09:53 AM
sgolds's Avatar
About those tiny shiny black plastic vac lines with the Comfortron setup, just how were they attached from the factory? seems like once they're off they won't go back on again. Were they heated and shrinked to connect them?
Old Dec 23, 2021 | 02:44 PM
Loaded68W34's Avatar
They are rubber, they just push onto the fittings. From age they get hard and keep their shape especially depending on where/ how the car was stored. If you are having difficulty with them, you can use a razor blade to cut off the expanded end and use a heat gun or hair drier to put a little heat into the end allowing it to get soft enough to slip onto the fitting.
Old Dec 24, 2021 | 09:30 AM
sgolds's Avatar
Must be a very different kind of rubber, very hard shiny almost looks like plastic. Very tiny lines that connect the Comfortron modules under the hood. They don't seem to bend or flex, very rigid.
Does anyone reproduce these?
Old Dec 24, 2021 | 11:57 AM
I don't know of anyone who reproduces them with the colored stripes in the small size. You can replace all of them with small diameter rubber vacuum hose as long as you keep track of where each end connects to.
Old Dec 24, 2021 | 12:00 PM
Yellowstatue's Avatar
Corvette also uses those hard plastic lines. That's another source.
Old Dec 25, 2021 | 11:23 AM
sgolds's Avatar
Thx for the info, are the vette lines this small?
Old Dec 25, 2021 | 01:59 PM
Yes, the Vette lines are tiny. 1/8" or so. The line pushes into rubber junctions.
sgolds
Dec 14, 2020 05:49 PM
1969w3155
Oct 5, 2015 10:24 PM
fred a
Mar 10, 2012 09:22 AM
TheBirds
Sep 24, 2010 09:40 AM
chris weber
Apr 1, 2009 03:30 PM
