Extracting a Ball Joint!
Old Oct 6, 2022 | 01:44 PM
Gauchobyte's Avatar
Angry Extracting a Ball Joint!
Hi: I am in the process of extracting the upper ball joint on a Toro 67 so I can take away the knuckle and then the drive shaft, all steps necessary, according to the CSM, for replacing my left hand side CV Boot. It should be be pretty stratight forward acording to the CSM also, pry and tap with a brass drift and so be it!, far for that I am stuck and the ball joint refuse to be extracted, I have used a fork with a big hammer to no avail, any tip, guidance or else will be greatly appreciated. Best Regards. Raul.
Old Oct 6, 2022 | 02:32 PM
If you have an acetylene torch you can always try to heat up the control arm (even a propane torch might help). Don't get it too hot or the control arm may warp.
Old Oct 7, 2022 | 12:30 PM
Gauchobyte's Avatar
Smile
Hi Jesse: Thanks for the tip, I finally managed to pull it out by using a generic extractor that works like a scissor (see photo) which was perfect for the job, unfortunately the quality of the tool was not enough for the job (the adjusting screw began to compress at its tip) but then I assisted with a heat gun over the knuckle and ... CLANK, it came out!!!!
t!!. Now lets see how the bottom ball joint will behave!
Old Oct 7, 2022 | 01:30 PM
Good luck with the lower ball joint. You can also soak it with PB Blaster for a day or two before trying to remove it.
Old Oct 7, 2022 | 03:39 PM
I do it this way.
Old Oct 16, 2022 | 06:22 AM
Gauchobyte's Avatar
Talking
Just for closure I managed to extract the lower ball joint!, as expected it was harder than the upper but after adapting and reinforcing with the help of a workshop another puller it wnet flawlessly. So happy to clear everything so I can pull the left dirve axle out except .... to be continued. Thanks as always. Best.
tkcutlass
May 21, 2024 04:02 PM
leroycjr
20
Jan 10, 2018 03:48 PM
cus
Drivetrain/Differentials
Dec 3, 2017 09:45 PM
f85mark
Nov 30, 2009 12:13 PM
65 starfire
Jan 29, 2008 11:06 AM
