66' Toro wiring harness
Old Oct 30, 2022 | 08:07 AM
ourkid2000's Avatar
Good day all,
Does anyone have any insight on how the heavy gauge wiring for the charging and voltage regulator is routed and connected in the 66' Toronado? I've had a good look at mine, on the underhood side at least, and have attached a crude drawing of how it's laid out as far as I can see. It all seems to go into the cabin and who knows where it goes from there. I'm curious how the wiring gets from the alternator back to the horn relay/junction block.
Thanks!
66 Toro wiring harness
Old Nov 1, 2022 | 09:36 PM
RA050626's Avatar
I don't know if you saw it, but 68RocketAction has a Sticky near the top of the forum page with a 1966 Toronado Assembly Manual. I believe if you download it, wiring is in Section 12. Or I believe someone posted a color wiring schematic if you check the archives. Hope this helps.
Old Apr 26, 2023 | 06:30 PM
KaydenST's Avatar
There is a splice somewhere in the harness where it splits and supplies power to a number of different things. I've never torn into the harness to find the splice though.
File Type: pdf
Old Apr 27, 2023 | 08:09 AM
RA050626's Avatar
Thanks, you are correct about the splices. And Thanks for the schematic.
Old May 21, 2023 | 02:07 PM
cfair's Avatar
You may want to keep it original, but be aware that these cars can benefit from a swap over to an internally regulated alternator with higher output than they had in 1966. I think factory was 65 amps or so, later ones put out 95 amps and higher. This is good if you’re planning on adding a later stereo, or other electronic doo-dads.
There are good instructions here somewhere about doing the swap to a later 10si or 12si unit. Either one or both should swap in place of the existing alternator. The voltage regulator was good for its time, but solid state works better - better charging at low rpm, less to mess with, fewer wires to break.
Just FYI.
Chris
ourkid2000
Oct 16, 2022 11:44 AM
JohnCobb
Mar 20, 2020 07:44 PM
bobfo1
May 26, 2013 05:22 PM
XTREMEGSXR
Jun 5, 2012 10:29 AM
stuart
Aug 14, 2004 02:24 PM
