‘67 Cowl - screen or not?
Old Aug 25, 2025 | 01:17 PM
BSiegPaint's Avatar
I’m doing some long needed cleaning of the cowl and the fender cavities, and I’m realizing there is no screen under the cowl vent openings, as I believe there should be. Am I right? If there was even the most modest of screens, most of this junk wouldn’t be jammed deep into these crevasses!
Old Aug 25, 2025 | 03:13 PM
Oldsmaniac's Avatar
Yes one should be there, possibly they are reproduced.
Old Aug 25, 2025 | 04:29 PM
They are. I've seen them recently and if I can remember where, I'll post a link.
You definitely need one.
Old Aug 25, 2025 | 04:33 PM
BSiegPaint's Avatar
Thank you! It may not be terribly original, but I'll use some 1/8" galvanized hardware cloth for the replacement piece unless there really is a supplier out there.
Old Aug 25, 2025 | 05:29 PM
Well, if you Google "'68-72 GM A-body cowl screen" you get quite a selection. Thing is, the mesh in most of them appears to be coarser than what I recall as factory. But take a look, it'll give you some ideas.
Old Aug 27, 2025 | 11:06 AM
BSiegPaint's Avatar
Bought some 12”x24” 8-mesh stainless screen from Amazon, painfully cut it into the correct shape and painted it, then shot the whole cowl and grille with a rattle can match. I’ll buff it out in a couple weeks when it’s fully cured, but for now, the cowl is properly protected from falling leaves and crawling mice.
Old Aug 28, 2025 | 09:13 AM
Well done. It actually looks more correct than the stuff I saw online. Guessing it was a lot more work, though.
Old Aug 28, 2025 | 10:23 AM
That cowl cover doesn't look stock, the vent area on mine almost goes from one side to the other. And your right wiper shaft is outboard?
Not my car, pulled off the net.
1967 Oldsmobile Cutlass | GM Sports
Old Aug 28, 2025 | 10:45 AM
Yeah, that's kind of different. Good catch!
Old Aug 28, 2025 | 11:54 AM
Loaded68W34's Avatar
That is because you guys are in the Toronado section (sub-forum). The car in question is a 67 Toronado not a 67 cutlass.
Old Aug 28, 2025 | 01:03 PM
F*ck.
Old Aug 28, 2025 | 02:29 PM
Silly me...
Mcnealolds
Jun 30, 2025 04:55 PM
jpeahuff12
Oct 24, 2023 02:35 PM
brianbeez67
Dec 7, 2020 09:42 AM
Ranzan
Dec 24, 2014 05:27 AM
David Wrenn
Dec 15, 2011 09:42 AM
