Cowl tag decode
Old Jun 29, 2025 | 05:48 PM
Mcnealolds's Avatar
Cowl tag decode
Hello all,
looking for a little assistance to decode to cal.Tank and motor number on my 67 oldsmobile Delta 88.Thank you for any help
Old Jun 29, 2025 | 06:30 PM
69CSHC's Avatar
04C = build date 3rd week of April
67 = model year
35887 = Delta 88 Holiday Coupe
BC = assembly plant, South Gate, California
1456 = unit number
366 = interior, Turquoise, cloth
YY = paint color, Saffron, up and down
C60 = air conditioning
Old Jun 29, 2025 | 06:38 PM
Mcnealolds's Avatar
What an odd color combination!!
Old Jun 29, 2025 | 07:34 PM
69CSHC's Avatar
Agreed !!
Although the turquoise interior is beautiful and looks great up against a white Delta.
https://classiccars.com/listings/vie...innesota-55358
Old Jun 29, 2025 | 08:02 PM
69CSHC's Avatar
With regards to the engine it should be and can only be a 425, and available hp range was 300-375.
Here below to familiarize yourself with the engine, from fellow member and Moderator 2blu442.
Originally Posted by 2blu442
The location of a motor block casting number, this one a 1967 425
Here's a closeup of the 1967 425 casting number. Note the large "D" at the end
Here's the vin pad on the 1967 425. There is no vin stamped in it as this didn't begin until 1968, but this is an idea where it's located on the 1968 and newer.
Post #1 here. https://classicoldsmobile.com/forums...engines-13691/
Old Jun 30, 2025 | 04:55 PM
67OAI's Avatar
Old(s)GuysRule
The engine unit number appears to be stamped incorrectly. By that I mean in all 1967 V8 engines there is supposed to be a prefix letter stamped followed by the unit number of that engine type and followed sometimes by a suffix letter. I do not see a prefix letter in the stamping but what looks like a letter "P" is stamped following the unit number. Since there are no letter "P" as suffix letter noted in the 1967 engine chart attached, it makes me wonder if it was stamped incorrectly. A letter "P" as prefix with no suffix letter indicates a 425 2bbl high compression engine; see the attached chart copied out of the 1967 Chassis Service Manual. Also, if you have the Protect-O-Plate we can help you decode that item.
442b
Jan 6, 2024 09:56 AM
BHM442
Jul 1, 2023 03:18 PM
72 Post
Jul 8, 2021 06:08 AM
Adam Michael
Apr 30, 2021 08:30 AM
83Delta88
Apr 8, 2020 03:55 AM
