Hi guys, I have the car nearly ready for paint. I started it up yesterday for some friends and not a problem. I go out there today and I have zero power in the cabin. I checked the continuity of the fusible link as well as all the things connected to the horn relay post. I’m a bit stumped, any ideas would be helpful Thanks in advance…Mark
A bit more info, I have 12 volts to the relay and also 12 volts at the other end of the respective wires except the one going to the hei distributor with the key on, on.
It was the black wire that goes to the cabin had separated completely under some black tape
This is the old girl. I have tried to keep it as original as possible but the ac system was toast.
This is how I solved the interference between the hei and air cleaner. I bought the air cleaner on ebay from Bukarest Hungary. It’s not from a Toronado but that tirned out to be an advantage.
