1966 Toronado Late Upshifting and doesn’t down shift
Old Feb 4, 2023 | 09:12 PM
Brsharp's Avatar
Hi My 1966 Toronado doesn’t upshift till about 55 mph normal driving and when floored it doesn’t downshift
i can make it up shift and downshift manually
Any ideas?
Randy
Old Feb 4, 2023 | 09:20 PM
Have you checked to see if your automatic transmission modulator line is attached to the transmission valve and a good vacuum source?
Old Feb 4, 2023 | 09:49 PM
Brsharp's Avatar
I will check that in the AM
thanks
Old Feb 4, 2023 | 09:58 PM
No cracks in the rubber vacuum hoses which attach to the metal line (might need to replace with new), no transmission oil leaking from the valve at transmission (valve may need replacement).
Old Feb 4, 2023 | 10:07 PM
Brsharp's Avatar
valve at transmission meaning modulator?
Old Feb 4, 2023 | 10:22 PM
Yes. Modulator valve is installed in transmission which is where line attaches.
Old Feb 4, 2023 | 10:25 PM
Brsharp's Avatar
I’ll check
thanks
Old Feb 5, 2023 | 06:37 AM
Verify that your kickdown switch isn't shorted. Pull the plug from the switch or trans (whichever is easier to reach) and see if it upshifts. If not, the problem is likely the vacuum modulator or the vacuum signal to the modulator. You can temporarily tee a vacuum gauge into the line that runs to the vac modulator at the trans and see what vacuum readings look like.
Old Feb 6, 2023 | 09:00 AM
ourkid2000's Avatar
Is it possible that his kickdown solenoid is stuck open (electrically good but physically stuck)? So it would be in "kickdown" mode always?
Old Feb 6, 2023 | 09:08 AM
Which is why I suggested disconnecting the plug in post #8 above. FYI, the kickdown solenoid valve is normally open. When voltage is applied it closes to engage the kickdown.
Old Feb 6, 2023 | 09:31 AM
ourkid2000's Avatar
You 100% on that? I could have sworn I read in the CSM that the kickdown on the TH425 is a normally closed, powered open switch.
Old Feb 6, 2023 | 09:32 AM
ourkid2000's Avatar
This video shows what I mean:
TH400, I know, but similar. You can see how the valve is normally held closed and powered open @ the 1:15 mark. Unless I'm completely misunderstanding.......which is entirely possible.
Old Feb 6, 2023 | 10:05 AM
You are correct. My apologies. I swear I read it as normally open, but the CSM clearly shows that it is not. Thanks for catching that.
Old Feb 6, 2023 | 10:23 AM
ourkid2000's Avatar
Finally! I got one over on Joe! I believe this calls for a celebration.
shiftbyear
Nov 28, 2021 12:39 PM
smietana
Dec 28, 2018 08:48 AM
wim lesabre59
Jun 28, 2018 11:12 PM
jaunty75
Jul 26, 2015 05:15 PM
ed burke
Apr 3, 2015 03:06 PM
